Where is the LISP reference help file in AutoCAD 2012?
4 REPLIES 4
patrick.emin
1896 Views, 4 Replies
Everything is in the title...
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Tags (3)
4 REPLIES 4
Shneuph
in reply to: patrick.emin
AutoCAD's Help menu's have been failing lately!  In 2010 I have a link in my favorites for "C:\Program Files\AutoCAD Civil 3D 2010\Help\acad_dev180.chm"  If you look in the help folder for 2012 you should find a file with a similar name "DEV" is what you're looking for.  This is for 'Developer' help I think.
If this doesn't work try typing vlide in the command line.  This opens the Visual LISP IDE then hit F1 for help and it should take you there.
Good Luck.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
patrick.emin
in reply to: Shneuph
I forgott to mention I am using a french version... Well in the mean time I found out that the help files are in my local install but not accessible when I press F1, this is probably because someone at Autodesk though french users cannot read english... How could I possibly restore this LISP help files to be accessible when I press F1? Thanks.
Shneuph
I think you can add a keyboard shortcut to Help...  Try adding it in the main CUIx.  (See image)
patrick.emin
Yes but this will not restore contextual help.
”Boost
