Visual LISP, AutoLISP and General Customization
Valued Contributor
AR12
Message 1 of 4 (153 Views)
Weird issue with the Start Up Suite Contents...
153 Views, 3 Replies
10-11-2012 08:11 AM
Ok So here's my problem,
I have a lisp file that is loaded via the Startup Suite Contents, Under the Loaded Applications Tab in the Load Applications Dialog Box, it lists it as being loaded, but none of the commands from this lisp file are working. How do I fix this?
Adam Richardson
If needed: AutoCAD 2013 User using Visual LISP for editing LISP and DCL files
*Expert Elite*
hmsilva
Message 2 of 4 (146 Views)
Re: Weird issue with the Start Up Suite Contents...
10-11-2012 08:40 AM in reply to: AR12
Any error message?
Henrique
Valued Contributor
AR12
Message 3 of 4 (138 Views)
10-11-2012 08:53 AM in reply to: hmsilva
Only message I get is if I try to put (C:HAZOPEN) which is one of the functions in the lisp file, which is Error: no function definition: C:HAZOPEN or if I just type HAZOPEN I get HAZOPEN Unkown command "HAZOPEN". Press F1 for help.
Adam Richardson
Valued Contributor
AR12
Message 4 of 4 (135 Views)
10-11-2012 09:00 AM in reply to: AR12
So I was looking at something else and scrolled up after hitting F2 and found a Malformed LIst on Input and realized that one of my other Lisp files wasn't finishing loading, and that was probably what was killing the other one. I missed a end quote on one of my functions and thus it wasn't letting everything load
Adam Richardson
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
