Hi Guys,
does anyone seen this?
a custom toolbar menu macro running a command that echo a command line options using sqaure brackets (like -layer) if it starts with double pauses? the command line window does not echo the prompt
[example]
^C^C-LAYER \\
[or]
^C^C-LINETYPE \\
from ribbon it works fine
this weird behaviour is only from R2013+
possible solution?
thanks for any help
Moshe
Solved by hmsilva. Go to Solution.
