how to determine if a string is a valid floating number, ie does not contain any invalid chars etc
i came out with this, but seems too complicated, i am suspecting an easier solution
(setq str "11.25")
(wcmatch str "*@*,[`~```@`#`$`%`^`&`*`(`)`-`_`+`=`[`]`{`}`|`\`;`:`\"`'`,`<`>`?`/")
TIA
Solved by SomeBuddy. Go to Solution.
You could use something like this:
(defun chkval (str)
(if (numberp (read str))
(alert "It's a number")
(alert "It's not a number")
(princ)
Usage:
(chkval "11.25")
(chkval "11.qr")
HTH
it helps, although i am intigued how a string like "12,44" a comma instead of a period is handled correctly by lisp,
(read "12,44") returns 12 but then numberp function is able to reject it.
it works, thanks
m
You're welcome.
(read "12,44") returns 12,44 on my machine and this is not a valid number for the LISP interpretor, since it "knows" that the decimal separator is the period and not the comma.
@SomeBuddy wrote:....
(defun chkval (str)
(princ)
Might the strings ever include spaces? For instance:
(chkval "30 days")
says it's a number.
Hmm,
This (read...) function is so dumb. The following will do better, except for the case where the string is entered using the scientific units type, i.e. using the "e-" or "e+" notation, which is quite rare:
(defun chknum (str) (if (vl-remove-if '(lambda (x)(or (wcmatch (chr x) "#")(= (chr x) "."))) (vl-string->list str) ) (alert "It's not a number.") (alert "It's a number.") ) (princ) )
had to add to the if condition
(if (and ...
(< (length (vl-remove-if-not '(lambda (x)(= x 46))(vl-string-list str))) 2) ...
to allow only 1 period or no period
still think there should be an easier way, a combo of rtos / atof / distof /atoi / itoa ?
I understand the two periods issue, but I don't understand the no period one. Maybe this one is good enough:
(defun chknum (str) (if (not (distof str)) (alert "It's not a number.") (alert "It's a number.") ) (princ) )
@SomeBuddy wrote:I understand the two periods issue, but I don't understand the no period one. Maybe this one is good enough:
.... (if (not (distof str)) ....
No periods = integers, which they do want to allow. But testing for quantity of periods doesn't appear to be necessary, given that (distof) seems to be the magic function that does the trick [at least, I haven't hit on any type of string content that fools it.]
some minor issues w/ distof ... a leading space, inch/foot signs, forward slashes (of course depending on the units setting)
to make clear my intentions, i am trying to test input in a dialog edit box for a valid number, be it integer or float.
thank you Kent & Some
m
<No periods = integers, which they do want to allow.>
I know what no period means, but what I was saying is that I don't see why is this alternative mentionned as an issue, while for me, the solution posted at that time was doing fine with integers.
You're welcome. I was supposing that this is what you want to do with it, i.e. validating some user input 🙂
Integers weren't an "issue," but one of the approved conditions ["allow only 1 period or no period"]. It was only a string with more than one period that was the issue, because that routine considered such a string to represent a number. Their added check was only to ensure that such a string would not pass.
The inch/foot signs and the forward slashes should be controlled using the proper mode (units settings) but for the leading space(s) you can improuve the code a little bit using something like:
(if (distof (vl-string-trim " " str)) (alert "It's a number.") (alert "It's not a number.") )
Regards
