Visual LISP, AutoLISP and General Customization
vla-put-path
2 REPLIES 2
919 Views, 2 Replies
vla-put-path
I just did a command to remove the xref path using VLA-PUT-PATH. It work well, but the display of the new path is not correct. It's still have the old path. I have to close the drawing, and open it again to have the display of the new path.
Is there a VL fonction to refresh the display of new information in the Dialog Box as the one for the Xrefs?
Thanks.
Marcel
2 REPLIES 2
phanaem
Try this
(defun C:TEST (/ *error* ss xref new_path)
  (defun *error*  (msg)
    (if	(not (member msg '("Function cancelled" "quit / exit abort")))
      (princ (strcat "\nError: " msg)))
    (princ)
  (if
    (and
      (setq ss (ssget ":E:S" '((0 . "INSERT"))))
      (eq
	(vla-get-IsXref
	  (setq	xref
		 (vla-item
		   (vla-get-Blocks
		     (vla-get-ActiveDocument (vlax-get-acad-object))
		   (vla-get-EffectiveName
		     (vlax-ename->vla-object (ssname ss 0))
	:vlax-true
      (setq new_path (getfiled "Select new Xref path" "C:\\" "dwg" 8))
     (progn
       (vlax-put xref 'Path new_path)
       (vlax-put xref 'Name (vl-filename-base new_path))
       (vla-reload xref)
  (princ)
 Some error trap still need, i.e. if you try to attach a dwg with the same name as a block existent in your drawing.
in reply to: phanaem
I needed only the vla-reload !
Marcel
”Boost
