vla-IntersectWith sometimes un-predictable?
0 REPLIES 0
Message 1 of 1
mdhutchinson
149 Views, 0 Replies
Why is vla-IntersectWith sometimes un-predictable...?
passing in two objects (obj1 and obj2) or in the reverse order seem to yield different result. With two objects I am trying with it (a closed LWpolyline and a Region). One order yields more points then the other.
Why...
And how might i approach this to make certain I am getting the points I need?
What I am attempting is to automatically dimension the length, width and centroid of a 2d region object. The idea was to create a temporary bounding rectangle, do IntersectWith and then test the points found to get the four points I want - then pass these to the dimension command.
0 REPLIES 0
”Boost
