I've been tryign to find a command reference that contains the Visual Lisp vla- prefixed commands, but I can't seem to find one. Every one I find goes straight from vl-vlx-loaded-p to vlax-3d-point.
Does anyone know where I can find a reference for the vla- commands?
Solved by rkmcswain. Go to Solution.
Another option is to use the Apropos Window in the Visual Lisp Editor.
This video should show how:
http://screencast.com/t/zV5toODEzg
If you cant view the video, Open the Visual Lisp Editor in AutoCAD
Go to View --> Apropos Window
Type in vla-
select the function you wish to learn about
Click the help button ?
