Visual LISP, AutoLISP and General Customization
VBA to VLISP
4 REPLIES 4
dolives
771 Views, 4 Replies
VBA to VLISP
How can i translate VBA syntax :
 currMenuGroup.Menus.item(i).item(j).SubMenu.item(k).Caption
In VLISP
I want to find a submenu in a partial menu like :
TPS
     " Test"
"Subtest-versionnumber"
To compare the version number !
Thank you very much for your help
Daniel OLIVES
(french user)
4 REPLIES 4
Moshe-A
in reply to: dolives
Daniel,
; get root pointer to menus
(setq menuGrp (vla-get-menugroups (vlax-get-acad-object)))
; get a pointer to acad.cuix file
(setq acadcui (vla-item menuGrp "acad"))
; get the menus
(setq menus (vla-get-menus acadcui))
; get file menu
(setq file-menu (vla-item menus "&File"))
 ; get the first  menu item
(setq item1 (vla-item file-menu 0))
 ; get the second menu item
(setq item2 (vla-item file-menu 2))
; get the fivth  menu item
(setq item5 (vla-item file-menu 5))
; get caption
(setq caption5 (vla-get-caption item5)) ; return "&Close"
Cheers,
Moshe
dolives
in reply to: Moshe-A
Thank you for your help.
I find a direct way without any control !
(setq LabelSubMenu
	(vlax-get-property
		(vla-item
			(vla-get-submenu
				(vlax-invoke-method
					(vla-item
						(vla-get-Menus
							(vla-item
								(vla-get-MenuGroups
								0
						0
					'Item
					20
			0
		'label
The menu index for my exemple is "20" and in submenu first so "0" !
I search a best way and post it !
 Daniel OLIVES
dolives
HI,
Screen shot menu !
Daniel OLIVES
dolives
I use this way to an automatic reload of mpartial menu when I update it.
I control if the labet of version is correct and if not i reload !
It work in VBA, but before migrate to dot net, i convert all in VLISP !
It is a good exercice !
Because i think it is very important to know how do al things in VLISP or LISP in AutoCAD so after it was easy to know how is possible or not !
Daniel OLIVES
”Boost
