VBA routine
5 REPLIES 5
291 Views, 5 Replies
VBA routine
I have a VBA routine that I received from a customer to use to create
glass sizes on curtain wall elevations. They have several inhouse menus
loaded when they start Acad that obviously give the VBA routine a start
command of GS at the command line. I of course don't have all of their
customization loaded so GS does not work for me. I know nothing about
VBA code and am wondering if there is a way to start the code without
whatever creates the keyboard shortcut? I'd have to get their permission
to post the code if that's what it takes
thanks,
Dave
DDP
5 REPLIES 5
Tools>Macro>Macros ...
Pick one from the list and click run.
If you're lucky there will only be one macro to pick from. If there is more
than one, start with the one who's name makes the most sense.
HTH
After following Gary's advice and finding the Macro name to run the command,
define a command GS by adding the following to one of your automatically
loading lisp files.
(Function C:GS ()
(VL-LOAD-COM)
(VL-VBARUN "Filename.DVB!MacroName")
Laurie Comerford
CADApps
www.cadapps.com.au
www.civil3Dtools.com
"Gary McMaster" wrote in message
news:5699357@discussion.autodesk.com...
HTH
Laurie Comerford wrote:
> Hi,
> loading lisp files.
> (Function C:GS ()
> (VL-LOAD-COM)
thanks for the help! I'm getting a syntax error when running the above code
Command: (Function C:GS ()
(_> (VL-LOAD-COM)
(_> (VL-VBARUN "GlassSizer.dvb!basGlassSize.GlassSize")
(_> )
Error: syntax error
I'd also like to autoload the .dvb file. Would this work if added to the
above?
(VL-VBALOAD "GlassSizer.dvb")
Dave
DDP
Hi Dave,
The VL-VBARUN command checks if the program file is loaded and loads it if
necessary.
Hence the VL-VBALOAD function is not necessary.
The syntax looks OK. Unless you have more than one "GlassSize" sub in the
program try
(VL-VBARUN "GlassSizer.dvb!GlassSize") from the command line.
This assumes the GlassSizer.dvb program is in the AutoCAD search path.
Otherwise you need to add a path string to allow the file to be found.
Laurie Comerford
CADApps
www.cadapps.com.au
"ddpcad" wrote in message
news:5699398@discussion.autodesk.com...
> Hi,
> command,
> loading lisp files.
> (Function C:GS ()
> (VL-LOAD-COM)
(_> (VL-LOAD-COM)
(_> )
Error: syntax error
above?
Dave
DDP
> Hi Dave,
> necessary.
> program try
Thanks Miss VBA Wiz! 🙂 the macro name should have been !GlassSize not
!GlassSize.Glasssize. Works now
Dave
DDP
ps: thanks to Gary for his input also!
”Boost
