Hi there (hope this is in the right area)
Very green to the whole LISP and VBA thing, so please be patient. We are currently running a standalone (custom coded for us) utilty that extracts info from a CAD drawing. Has worked great since 2006 until now.
We are upgrading to Windows 7, and this utility seems to choke on the 64 bit Windows platform. Works flawlessly on a 32 bit XP machine
We I start the extraction (just a cross window on CAD, I get the follwing error"Error loading ActiveX DLL"
When I look at the LISP I can see the area where the stumbling block is, but dont have the foggiest idea how to fix it.
Is this a 64 bit Windows 7 issue or a DLL issue or VBA???..........or wayyyy deeper than that.
Just wondering if this entire utility needs to be re-written to work on 64 bit or if the exisitng is fixable.
thanks in advance for any advice or if more info is required.
snippet of my LISP below (that contains the error)
; This function initializes the activeX interface
(defun initActiveX ()
(if (car (atoms-family 1 '("vl-load-com"))) (vl-load-com))
(setq vbApp (vlax-get-or-create-object "HHSBAcad.HHSB"))
(if (not vbApp)
(progn
(princ "\nError loading ActiveX DLL.")
nil
T
; Process the data from the appropriate title block and pass it to the activeX instance
(defun processTBlockData ()
; Now you need to build the list of attribute data for the titleblock
(setq tblockdata "")
(setq ss nil)
; Select the appropriate title block
(setq ss (ssget "X" (list (cons 0 "INSERT") (cons 2 TBlockName) (cons 410 PSpaceLayout))))
