It looks like you are trying to open a file dialog box from your VBA
program and store the selected file name in a variable.
You can do that much more elegantly and easier using the CommonDialog in
VBA. I have attached the CmDlg.CLS file for your use. Attach this into
your project and use the following code to call up the file browse.
Dim fn As New Cmdlg
Dim fileName as String
With fn
.InitDir = ""
.FileName = ""
.Filter = "File to open" & vbNullChar & "*.*" & vbNullChar & vbNullChar
.DialogTitle = "Enter name of file to create"
.Flags = StandardFlag.OpenFile
.ShowOpen
fileName = .FileName
End With
Hope this helps.
Regards
Rakesh
cad007 wrote:
> Hello,
> how execute an autolisp function via vba, I know that there is the
> function sendcommand but I would like an example for better
> understanding and especially to recover a variable.
> For example I have an instruction autolisp:
> (setq var1 (getfiled "To give file" "" "" 0))
> and with VBA I would like to execute this instruction and at the same
> time recover the contents of the variable var1
> Thanks
AutoCAD customization for Engineering/Mapping/GIS
Get GeoTools @ http://www.4d-technologies.com/geotools
Build MyGeoTools @ http://www.4d-technologies.com/geotools/my_geotools.htm
FREE downloads : http://www.4d-technologies.com/techcenter
VERSION 1.0 CLASS
BEGIN
MultiUse = -1 'True
END
Attribute VB_Name = "Cmdlg"
Attribute VB_GlobalNameSpace = False
Attribute VB_Creatable = False
Attribute VB_PredeclaredId = False
Attribute VB_Exposed = False
Option Explicit
' Cmdlg Class Module by Four Dimension Technologies, Bangalore
' initialize the UDT
Public Enum Flag
OFN_ALLOWMULTISELECT = &H200
OFN_CREATEPROMPT = &H2000
OFN_ENABLEHOOK = &H20
OFN_ENABLETEMPLATE = &H40
OFN_ENABLETEMPLATEHANDLE = &H80
OFN_EXPLORER = &H80000
OFN_EXTENSIONDIFFERENT = &H400
OFN_FILEMUSTEXIST = &H1000
OFN_HIDEREADONLY = &H4
OFN_LONGNAMES = &H200000
OFN_NOCHANGEDIR = &H8
OFN_NODEREFERENCELINKS = &H100000
OFN_NOLONGNAMES = &H40000
OFN_NONETWORKBUTTON = &H20000
OFN_NOREADONLYRETURN = &H8000
OFN_NOTESTFILECREATE = &H10000
OFN_NOVALIDATE = &H100
OFN_OVERWRITEPROMPT = &H2
OFN_PATHMUSTEXIST = &H800
OFN_READONLY = &H1
OFN_SHAREAWARE = &H4000
OFN_SHAREFALLTHROUGH = 2
OFN_SHAREWARN = 0
OFN_SHARENOWARN = 1
OFN_SHOWHELP = &H10
OFS_MAXPATHNAME = 128
End Enum
Public Enum StandardFlag
OpenFile = Flag.OFN_EXPLORER Or Flag.OFN_LONGNAMES Or Flag.OFN_CREATEPROMPT Or Flag.OFN_NODEREFERENCELINKS
OpenMulti = StandardFlag.OpenFile Or Flag.OFN_ALLOWMULTISELECT
SaveFile = Flag.OFN_EXPLORER Or Flag.OFN_LONGNAMES Or Flag.OFN_OVERWRITEPROMPT Or Flag.OFN_HIDEREADONLY
End Enum
Private Type OPENFILENAME
nStructSize As Long
hwndOwner As Long
hInstance As Long
sFilter As String
sCustomFilter As String
nCustFilterSize As Long
nFilterIndex As Long
sFile As String
nFileSize As Long
sFileTitle As String
nTitleSize As Long
sInitDir As String
sDlgTitle As String
Flags As Long
nFileOffset As Integer
nFileExt As Integer
sDefFileExt As String
nCustDataSize As Long
fnHook As Long
sTemplateName As String
End Type
Private Enum CmdlgErrors
CDERR_GENERALCODES = &H0
CDERR_STRUCTSIZE = &H1
CDERR_INITIALIZATION = &H2
CDERR_NOTEMPLATE = &H3
CDERR_NOHINSTANCE = &H4
CDERR_LOADSTRFAILURE = &H5
CDERR_FINDRESFAILURE = &H6
CDERR_LOADRESFAILURE = &H7
CDERR_LOCKRESFAILURE = &H8
CDERR_MEMALLOCFAILURE = &H9
CDERR_MEMLOCKFAILURE = &HA
CDERR_NOHOOK = &HB
CDERR_REGISTERMSGFAIL = &HC
FNERR_FILENAMECODES = &H3000
FNERR_SUBCLASSFAILURE = &H3001
FNERR_INVALIDFILENAME = &H3002
FNERR_BUFFERTOOSMALL = &H3003
FRERR_FINDREPLACECODES = &H4000
FRERR_BUFFERLENGTHZERO = &H4001
CDERR_DIALOGFAILURE = &HFFFF&
End Enum
Private OFN As OPENFILENAME
Private Declare Function GetSaveFileName Lib "comdlg32.dll" Alias "GetSaveFileNameA" (pOpenfilename As OPENFILENAME) As Long
Private Declare Function GetOpenFileName Lib "comdlg32.dll" Alias "GetOpenFileNameA" (pOpenfilename As OPENFILENAME) As Long
' the next two declares are unused but could be used to add other functions
Private Declare Function CommDlgExtendedError Lib "comdlg32.dll" () As Long
Private Declare Function GetShortPathName Lib "kernel32" Alias "GetShortPathNameA" (ByVal lpszLongPath As String, ByVal lpszShortPath As String, ByVal cchBuffer As Long) As Long
' make private variables used within the Class
Private m_bShowSave As Boolean
Private m_bCancelError As Boolean
Private m_sDefaultExtension As String
Private m_sDialogTitle As String
Private m_sFilename As String
Private m_sFiletitle As String
Private m_iFilterIndex As Integer
Private m_sInitDir As String
Private m_sFilter As String
Private m_bCancelPressed As Boolean
Private m_sFileExtension As String
Private m_lFlags As Long
Private m_bMultiSelect As Boolean
Private m_iMaxFileSize As Integer
Private m_lhWnd As Long
Public Sub ShowOpen()
Dim ret&
Call Initialize ' fill-in the OFN structure
ret = GetOpenFileName(OFN) ' open the dialog and see what we get back
Call HandleReturn(ret) ' process the return value
End Sub
Public Sub ShowSave()
Dim ret&
m_bShowSave = True
Call Initialize
ret = GetSaveFileName(OFN)
End Sub
Private Sub Initialize()
OFN.nStructSize = Len(OFN)
OFN.hwndOwner = m_lhWnd ' will not be modal if hWnd is not specified
OFN.sFilter = m_sFilter
OFN.nFilterIndex = m_iFilterIndex
If Len(m_sFilename) = 0 Then ' make a buffer depending on input
OFN.sFile = vbNullChar & String$(m_iMaxFileSize, 0)
Else
OFN.sFile = m_sFilename & String$(m_iMaxFileSize, 0)
End If
OFN.nFileSize = Len(OFN.sFile)
' only set it if a default ext is provided
If m_sDefaultExtension <> vbNullString Then OFN.sDefFileExt = m_sDefaultExtension
OFN.sFileTitle = String$(m_iMaxFileSize / 2, 0)
OFN.nTitleSize = Len(OFN.sFileTitle)
OFN.sInitDir = m_sInitDir
OFN.sDlgTitle = m_sDialogTitle
OFN.Flags = m_lFlags
End Sub
Private Sub HandleReturn(lReturn As Long)
Dim lError&
If lReturn > 0 Then ' 0 is returned when cancel is pressed
If (OFN_ALLOWMULTISELECT And OFN.Flags) = OFN_ALLOWMULTISELECT Then
Let FileName = OFN.sFile
Else
Let FileName = TrimNull(OFN.sFile)
End If
Let Filetitle = TrimNull(OFN.sFileTitle)
If m_bShowSave = True Then m_bShowSave = False
' the FileExtension property is read-only so the variable must be set
If Asc(Mid$(OFN.sFile, (InStr(OFN.sFile, vbNullChar)) + 1, 1)) = 0 And (OFN_ALLOWMULTISELECT = OFN_ALLOWMULTISELECT And OFN.Flags) Then ' test for MultiSelect or if ShowSave was chosen
m_sFileExtension = Mid$(OFN.sFile, OFN.nFileExt + 1, Len(OFN.sFile) - OFN.nFileExt)
m_bMultiSelect = False
Else
m_bMultiSelect = True
m_sFileExtension = ""
End If
If Not OFN_ALLOWMULTISELECT = (OFN_ALLOWMULTISELECT And OFN.Flags) Then m_bMultiSelect = False
m_bCancelPressed = False ' read-only also
Else
lError = CommDlgExtendedError()
If lError > 0 Then HandleExtendedError (lError)
Let FileName = ""
Let Filetitle = ""
m_bCancelPressed = True
End If
End Sub
Private Sub HandleExtendedError(cdlgError As Long)
Select Case cdlgError
Case CDERR_GENERALCODES: Err.Raise cdlgError, , "CDERR_GENERALCODES"
Case CDERR_STRUCTSIZE: Err.Raise cdlgError, , "CDERR_STRUCTSIZE"
Case CDERR_INITIALIZATION: Err.Raise cdlgError, , "CDERR_INITIALIZATION"
Case CDERR_NOTEMPLATE: Err.Raise cdlgError, , "CDERR_NOTEMPLATE"
Case CDERR_NOHINSTANCE: Err.Raise cdlgError, , "CDERR_NOHINSTANCE"
Case CDERR_LOADSTRFAILURE: Err.Raise cdlgError, , "CDERR_LOADSTRFAILURE"
Case CDERR_FINDRESFAILURE: Err.Raise cdlgError, , "CDERR_FINDRESFAILURE"
Case CDERR_LOADRESFAILURE: Err.Raise cdlgError, , "CDERR_LOADRESFAILURE"
Case CDERR_LOCKRESFAILURE: Err.Raise cdlgError, , "CDERR_LOCKRESFAILURE"
Case CDERR_MEMALLOCFAILURE: Err.Raise cdlgError, , "CDERR_MEMALLOCFAILURE"
Case CDERR_MEMLOCKFAILURE: Err.Raise cdlgError, , "CDERR_MEMLOCKFAILURE"
Case CDERR_NOHOOK: Err.Raise cdlgError, , "CDERR_NOHOOK"
Case CDERR_REGISTERMSGFAIL: Err.Raise cdlgError, , "CDERR_REGISTERMSGFAIL"
Case FNERR_FILENAMECODES: Err.Raise cdlgError, , "FNERR_FILENAMECODES"
Case FNERR_SUBCLASSFAILURE: Err.Raise cdlgError, , "FNERR_SUBCLASSFAILURE"
Case FNERR_INVALIDFILENAME: Err.Raise cdlgError, , "FNERR_INVALIDFILENAME"
' the first two bytes of OFN.sFile could also be passed along
' some sort of retry routine could be fashioned
Case FNERR_BUFFERTOOSMALL: Err.Raise cdlgError, , "FNERR_BUFFERTOOSMALL - Increase MaxFileSize to: " & CStr(Asc(Left$(OFN.sFile, 1))) & CStr(Asc(Mid$(OFN.sFile, 2, 1)))
Case FRERR_FINDREPLACECODES: Err.Raise cdlgError, , "FRERR_FINDREPLACECODES"
Case FRERR_BUFFERLENGTHZERO: Err.Raise cdlgError, , "FRERR_BUFFERLENGTHZERO"
Case CDERR_DIALOGFAILURE: Err.Raise cdlgError, , "CDERR_DIALOGFAILURE"
Case Else: Err.Raise 666, , "Unknown CommonDialog Error"
End Select
End Sub
Function TrimNull(s As String) As String
Dim lWhere&
lWhere = InStr(1, s, vbNullChar)
If lWhere > 0 Then
TrimNull = Left$(s, lWhere - 1)
Else
TrimNull = s
'Debug.Print s & " " & "no null present"
End If
End Function
Public Property Let InitDir(ByVal sInitDir As String)
m_sInitDir = sInitDir
End Property
Public Property Get InitDir() As String
End Property
Public Property Let FilterIndex(ByVal iFilterIndex As Integer)
If iFilterIndex = 0 Then iFilterIndex = 1
m_iFilterIndex = iFilterIndex
End Property
Public Property Get FilterIndex() As Integer
End Property
Public Property Let Filetitle(ByVal sFileTitle As String)
m_sFiletitle = sFileTitle
End Property
Public Property Get Filetitle() As String
Filetitle = m_sFiletitle
End Property
Public Property Let FileName(ByVal sFilename As String)
m_sFilename = sFilename
End Property
Public Property Get FileName() As String
FileName = m_sFilename
End Property
Public Property Let DialogTitle(ByVal sDialogTitle As String)
m_sDialogTitle = sDialogTitle
End Property
Public Property Get DialogTitle() As String
DialogTitle = m_sDialogTitle
End Property
Public Property Let DefaultExtension(ByVal sDefaultExtension As String)
m_sDefaultExtension = sDefaultExtension
End Property
Public Property Get DefaultExtension() As String
DefaultExtension = m_sDefaultExtension
End Property
Public Property Get CancelPressed() As Boolean ' read-only
CancelPressed = m_bCancelPressed
End Property
Public Property Get FileExtension() As String ' read-only
FileExtension = m_sFileExtension
End Property
Public Property Get MultiSelect() As Boolean ' read only
MultiSelect = m_bMultiSelect
End Property
Public Property Let Filter(ByVal sFilter As String) ' write-only
m_sFilter = sFilter
End Property
Public Property Let Flags(ByVal lFlags As Long) ' write only
m_lFlags = lFlags
End Property
Public Property Let hwnd(ByVal lhWnd As Long)
m_lhWnd = lhWnd
End Property
Public Property Let MaxFileSize(ByVal iMaxFileSize As Integer)
If iMaxFileSize < 1024 Then iMaxFileSize = 1024 ' set the minimum
m_iMaxFileSize = iMaxFileSize
End Property
' prepare the class with the minimun settings (in case nothing was set)
Private Sub Class_Initialize()
m_bShowSave = False
MaxFileSize = 2048
InitDir = ""
FilterIndex = 1
Filetitle = ""
FileName = ""
DefaultExtension = ""
Filter = "All Files (*.*)" & vbNullChar & "*.*" & vbNullChar & vbNullChar
End Sub
