Mike, I use the following for inserting a room number block with the number
increasing by 1 for each block inserted. It only works while the command is
active. If you restart, you must input the value to begin with.
In my .mns file I have the following line:
(setq BNR (GETINT "Beginning Number: "));\MULTIPLE;RMNO;
In my .mnl file I have the following:
(defun c:RMNO ()
(setq a (itoa bnr))
(command "insert" "box" "s" f pause 0 a)
(setq bnr (+ 1 bnr)))
Notice that you must set the value of "bnr" before you start the
multiple;rmno; command. This allows the value to increase each time the
block is inserted. Hope this helps.
Nick
"m.a." wrote in message
news:E51E6B6CCDB570B4D9987824DC5319DC@in.WebX.maYIadrTaRb...
> Hi;
> Currently this lisp routine inserts a block with attribute.
> Every time the same block is inserted, a dialog box
> pops up showing tag as numeral one (1), and I change it
> to a different number (sequentially increasing), and click
> OK to show the block with new tag (i.e. 1, 2 ,3 etc).
> Is there a way to (programmatically) increment the tag
> and display it as a new tag in the block (block is a circle
> with numbers inside) and then finish the insert command?
> Thanks
> mike
> My email address has name of a fruit in
> it. Please remove the fruit for email replies.
