Variables for Mleader routine
3 REPLIES 3
Raddis
574 Views, 3 Replies
Almost there!
(vl-load-com)
(defun mlcreate (/ *doc* mldrdict newldrstyle)
(setq *doc* (vla-get-activedocument (vlax-get-acad-object)))
(setq mldrdict (vla-item (vla-get-dictionaries *doc*) "ACAD_MLEADERSTYLE"))
(setq newldrstyle (vlax-invoke mldrdict 'addobject "CGA" "AcDbMLeaderStyle"))
(setq txtcol 0 ldrcol 0)
(setq colorObj (vla-getinterfaceobject (vlax-get-acad-object) "AutoCAD.AcCmColor.17"))
(vla-put-ColorIndex colorObj txtcol)
(vla-put-ColorIndex colorObj ldrcol)
(vlax-put-property newldrstyle 'AlignSpace 5.0)
;; Leader format
;;; (vlax-put-property newldrstyle 'ArrowSymbol "Arrowhead")
(vlax-put-property newldrstyle 'ArrowSize 0.125)
(vlax-put-property newldrstyle 'BreakSize 0.0625)
(vlax-put-property newldrstyle 'LeaderLineType 1)
(vla-put-LeaderLineColor newldrstyle colorObj)
(vlax-put-property newldrstyle 'LeaderLineTypeId "Bylayer" )
(vlax-put-property newldrstyle 'LeaderLineWeight -2)
;; Leader Structure
(vlax-put-property newldrstyle 'MaxLeaderSegmentsPoints 2)
(vlax-put-property newldrstyle 'FirstSegmentAngleConstraint 0)
(vlax-put-property newldrstyle 'SecondSegmentAngleConstraint 0)
(vlax-put-property newldrstyle 'EnableLanding -1)
(vlax-put-property newldrstyle 'EnableDogleg -1)
(vlax-put-property newldrstyle 'DoglegLength -2.0)
(vlax-put-property newldrstyle 'Annotative 1)
;; Content
(vlax-put-property newldrstyle 'ContentType 2)
(vlax-put-property newldrstyle 'Description "CGA")
(vlax-put-property newldrstyle 'TextString "")
(vlax-put-property newldrstyle 'TextStyle "technical")
(vlax-put-property newldrstyle 'TextAngleType 1)
(vla-put-TextColor newldrstyle colorObj)
(vlax-put-property newldrstyle 'TextHeight 0.09375)
(vlax-put-property newldrstyle 'TextAlignmentType 0)
(vlax-put-property newldrstyle 'EnableFrameText 0)
(vlax-put-property newldrstyle 'TextLeftAttachmentType 1)
(vlax-put-property newldrstyle 'TextRightAttachmentType 5)
(vlax-put-property newldrstyle 'LandingGap 0.029296875)
(vlax-put-property newldrstyle 'DrawLeaderOrderType 0)
(vlax-put-property newldrstyle 'DrawMLeaderOrderType 1)
(vlax-put-property newldrstyle 'name "CGA")
By default, this routine uses the Closed filled arrowhead but i'm wondering what the correct code for the 'ArrowSymbol variable is to do this.
And, more importantly, I want the text content Always Left Justified, but the 'TextAlignmentType variable doesn't seem to do this.
All help is appreciated!!
Reid
3 REPLIES 3
balisteor
in reply to: Raddis
For the Text Alignment type this works
( vla-put-TextAlignmentType newldrstyle 0 )
I Can't figure out the Arrowhead issue.
I just keep getting *Key not found* Error. : (
Raddis
in reply to: Raddis
Same here.
Why is it so difficult to set a closed filled arrow!
Raddis
in reply to: Raddis
That (this) doesn't do anything for text alignment.
”Boost
