Visual LISP, AutoLISP and General Customization
Value must be nonzero
6 REPLIES 6
kdoug
706 Views, 6 Replies
Hey everyone. Attached is a code that I wrote. I am getting an error and I can't figure out where the error is in the code. If someone would be so kind to take a look and push me in the right direction it would be greatly appreciated. Thanks!
Kdoug
6 REPLIES 6
in reply to: kdoug
Well, block insertion scale factors must be non-zero, so I'd look at those
first. Type !Crown on the Command prompt line to see whether it succeeded
in setting that as a numerical value. (You might have to take out the
localizing of variables temporarily to do it.) No one else can test it
without your job-number text file and so on, though someone better versed
than I in referring to external files like this might also have some
suggestions.
Kent Cooper
Kdoug
in reply to: kdoug
Offhand, I don't see the cause of the error you cite, but your (while ...)
loop will run indefinitely, since the test is a value that just keeps
incrementing indefinitely.
___
wrote in message news:5177705@discussion.autodesk.com...
Kdoug
kdoug
in reply to: kdoug
Thanks for the help. Now when I type in !Crown it is set to "ÿþ3\0000\000" Any Clues? Is this ASCII for 20 ? The external file I want to read is just a bunch of numbers.
Kdoug
in reply to: kdoug
My guess is it's more likely something in the opening and reading of the
external text file. If you run each line by itself, and see whether it
returns something appropriate, maybe you can find where it's going wrong.
Kent Cooper
wrote...
a bunch of numbers.
Kdoug
in reply to: kdoug
As Paul pointed out, the while is never ending.
By incresing cnt by 1 and using repeat ,you are reading the first
record the first time, then you read the next two, then the next 3, etc.
You are setting crown to what you read to use as a scale factor,
so apparently the file you have has a set of records with different
scale factors. When you reach the end of the file the scale factor
will not be correct. Once you get to the end you continue to try to
read the file, setting the scale factor to whatever garbage it finds at the
end of the file. This is probably where your error is.
Try this (untested)
(defun C:ITE (/ symbol i_point Crown t_type treeno jobno tfnam fnam)
(setq
oldecho (getvar "cmdecho")
oldblip (getvar "blipmode")
oldclyr (getvar "clayer")
(setq jobno (substr (getvar "dwgname") 1 5))
(setq tfnam (strcat jobno ".txt"))
(setq i_point (getpoint "\nSelect insertion point: "))
(setq treeno (getint "\nEnter Tree No: "))
(command "insert" symbol i_point Crown Crown "" treeno)
(set cnt 1)
(setq fnam (open tfnam "r"))
(if (not (tblsearch "LAYER" "EJK_SYMBOL_EXISTING"))
(command "LAYER" "N" "EJK_SYMBOL_EXISTING" "")
(setvar "clayer" "EJK_SYMBOL_EXISTING")
(setq symbol "ejk_t_ex_dec_1")
(while
(setq Crown (atoi (read-line fnam)))
(setq treeno (+ treeno 1))
(close fnam)
(setvar "cmdecho" oldecho)
(setvar "blipmode" oldblip)
(setvar "clayer" oldclyr)
(princ)
If you really only have one record in the txt file indicating the
scale factor to use for all inserts and you want the while to
continue until you quit selecting locations, then try this (untested).
(setq
(set cnt 1)
(close fnam)
(while
(princ)
wrote in message news:5177892@discussion.autodesk.com...
a bunch of numbers.
Kdoug
kdoug
in reply to: kdoug
I didn't have a chance yesterday, but I figured out the problem by eliminating the locals and testing. For whatever reason using (findfile was picking up a file other than the text file I wanted. I corrected it by adding:
(setq tfnam (strcat "C:\\EJK_JOBS\\EX_TREE_CROWNS\\" jobno ".txt"))
As for the while loop that is never ending, I've corrected that.
Thanks everyone for you help.
Kdoug
”Boost
