This piece of info is not in the dxflist. This is the point I've been trying
to make.
Thanks for your time though,
Mark
"Jeff Mishler" wrote in message
news:3BF57E8EA640E1C21DE74721D4AD4F1D@in.WebX.maYIadrTaRb...
> Mark,
> Use this to list a door in the drawing, then find the dxf code for the
> "swing type". You could then use that code in your ssget.
> (entget (car (entsel)))
> HTH,
> Jeff
> "Mark Ingram" wrote in message
> news:940B00D75BFDDF4AD74BF5AA769403BB@in.WebX.maYIadrTaRb...
> > Would either of you have a moment to show me the equivalent of
> > (ssget "x" '((0 . "AEC_DOOR")(? . "Single Swing")))
> > in vlisp?
> > I'm unable to get "Single Swing" from entget.
> > Thank you,
> > Mark
> > "michael puckett" wrote in message
> > news:E345AF7AD7EFF607A27A3B92ECB1B1A1@in.WebX.maYIadrTaRb...
> > > ... I loosely recall the "guru of gurus" pointing
> > > out that specifying method / property names by symbols
> > > ( eg 'StyleName, rather than strings, eg "StyleName" )
> > > was more efficient: a hundred calls using a string
> > > yields a separate instance of the string for each call,
> > > whereas using a symbol results in the creation of
> > > precisely one object with references for each subsequent
> > > call. The bottom line being that the latter is better
> > > coding practice, even though the performance hit, or
> > > additional memory consumption might be negligible.
> > > Something like that.
> > > "R. Robert Bell" wrote in message
> > > news:2505058AA8C6FE4B802FE1551E26C332@in.WebX.maYIadrTaRb...
> > > 8^P
> > > Can tell you're a Cana-dude, throwing out a hockey reference. Around
> here
> > > I'd blow the whistle and proclaim a 5-yard penalty...
> > > R. Robert Bell, MCSE
> > > www.AcadX.com
> > > news:C2CC1DCD127BAE52AE7266474DA3A9F9@in.WebX.maYIadrTaRb...
> > > | WHISTLE! 2 minutes, slow operation!
> > > | (vl-catch-all-apply
> > > | 'vlax-get-property
> > > | (list object 'StyleName)
