Hi everybody. I am trying to improve quality of exported drawings from Revit. We had troubles with lines and setting „by layer“. We found solution, but unfortunately we have to do it manually for each drawing. Is there any possible way how to program (by using LISP for instance) following commands?
See attached image…
I would appreciate any advice or help.
Thank you in advance
Pavel Prchal
You cannot script a dialog box. You would need to recreate what laytrans does within the context you have.
Maybe you can create a script to do this... Did you solve this problem? How?
