Visual LISP, AutoLISP and General Customization
use of handle property (OLE Object)
2 REPLIES 2
GeryKnee
304 Views, 2 Replies
I don't know if i am in the right forum.
I need help about how to use the handle property to retrieve an object
example
 suppose obj - a line for example is an OleVariant that is associated to the drawing object.
 OH = obj.handle is the unique handle (of type string) of object and can be used to retrieve the object , but
 trying to retrieve it , i use the reference
   SearchObj = Acad.ActiveDocument.ModelSpace.Item(OH)
  the below causes error , that means ModelSpace is the wrong collection the item belongs to
 So, what is the collection in wich i can find the object using handle
2 REPLIES 2
hgasty1001
in reply to: GeryKnee
Has been a lot of time since the last time i did VBA, but I think you can create an AcadObject with something like:
dim acobj as AcadObject
Set acobj=thisDrawing.HandleToObject(Handle)
Now you can test acobj for your needs.
Gaston Nunez
GeryKnee
in reply to: hgasty1001
thanks Gaston
That's good
Gery
”Boost
