guys i've forgotten how to write lisps as i havent written code since autocad 2000-2004
can anybody help me out?
i would like to be able to quickly edit the following properties
select a table
changet the table style
change the row heights (the first height 10, then the rest at 6)
change the cell widths (first at 10 then rest at 25)
change the cell format of one column to angular with no decimals
can anyone tell me what i need to type?
so far googled and found this which sort of works for me
(defun c:Rz()
(vl-load-com)
(setq tbl (vlax-ename->vla-object(car(entsel))))
(vla-setcolumnwidth tbl 0 10)
(vla-setcolumnwidth tbl 1 25)
(vla-setcolumnwidth tbl 2 25)
(vla-setcolumnwidth tbl 3 25)
(vla-setcolumnwidth tbl 4 25)
(vla-setcolumnwidth tbl 5 25)
(setq rows (vla-get-rows tbl)) ;;get number of rows
(setq currentRow 0)
(repeat rows - 2 ;;repeat for all the rows in the table
(vla-SetCellAlignment tbl currentRow 0 acMiddleCenter)
(vla-SetCellAlignment tbl currentRow 1 acMiddleCenter)
(vla-SetCellAlignment tbl currentRow 2 acMiddleCenter)
(vla-SetCellAlignment tbl currentRow 3 acMiddleCenter)
(vla-SetCellAlignment tbl currentRow 4 acMiddleCenter)
(vla-SetCellAlignment tbl currentRow 5 acMiddleCenter)
;;(vla-setrowheight tbl currentRow 1) ;Change row height (TEST)
(setq currentRow (+ 1 currentRow))
(vla-setrowheight tbl 0 10)
(vla-setrowheight tbl 1 6)
(vla-setrowheight tbl 2 6)
(vla-setrowheight tbl 3 6)
(vla-setrowheight tbl 4 6)
the last section is what i cannot get to work, most likely because acad doesnt recognise the command
any help guys?
camardi
if you are setting the row height, first you have to set text height
(vla-setcelltextheight table row colum height)
and the vertical margin
(vlax-put tbl 'VertCellMargin 1)
the [celltextheight + (2 x VertCellMargin)] equal to or greater than (row height)
i.e.
if your text height is set to 3 and the vertical cell margin to 1, now you can set the row height to 6...
hope that helps
Henrique
