Ohh, it's OK, I didn't try to point out any irelevance or whatever, but it was just an observation. Anyway, as I said, I didn't spend 30 minutes editing, it was rather some very reasonable amount of time, so I still hope for an answer from the concerned people.
One of the goals of the Autodesk Login was to centralize a single login & password for multiple Autodesk sites (Subscription, forums, community sites, etc.). Your findings are correct that the keep me signed in feature sets a cookie central to the login system, not to each specific site.
I guess I don't understand why you need two separate accounts. Is it just to maintain some level of anonymity in the forums, but not in Subscription? If so, you may need to avoid using that feature and just login/logout to each site as needed.
How long are you typically spending editing a message. I'm not aware of any settings that limit this time, but you may be encountering a browser session timeout.
As Jason pointed out, I was referrring to the time the "Edit" option is avaialble in the options dropdown.
@Anonymous wrote:
if you exceed a certain period of time, when you want to update the changes you will get a message saying that you exceeded the editing time and then the changes can not be posted.
SomeBuddy
I just opened an old post of mine... there was no option to edit.
So am I to believe that I can't edit posts older than 30 minutes?
What if I were to post some code and an hour later I realize I made a mistake... can't I edit it?
If that's the case, it sucks.
In that case I would reply to your own post with correction/clarification or use the report inappropriate content to request removal of the post altogether. How did you all manage in the old platform where you couldn't edit after someone replied?
Are you seeing the auto-save option to re-load a saved topic? Can you screenshot the error you receive?
@Anonymous wrote:if you exceed a certain period of time, when you want to update the changes you will get a message saying that you exceeded the editing time and then the changes can not be posted.
SomeBuddy
Thanks for the answer Eric, although is disappointing. I don't think this is something everybody wants and I think there's a lot of people wanting to keep their anonymity and a low profile. In fact I know that the anonymity was one of the biggest concerns of most of the people on the old NNTP interface and it holds true for this one, so it doesn't look like you have any intention to meet the expectations of these people.
In another train of thoughts, how is it possible that a forum site dedicated to AutoCAD customization doesn't accept the DCL extension as a valid one !?!?!?
Regards
@wrighte wrote:How did you all manage in the old platform where you couldn't edit after someone replied?
Kept replying to the thread with corrections. Which forced other readers
to view every single post to get the corrections, which pretty much stinks
when posting code.
Wasn't the idea here to improve the interface/functionality? Why even have
an edit feature at all, when it's virtually useless?
Fail.
.dcl added to allowed types. Good suggestion.
Best practice would be to zip attachments depending on size or if you have multiple files.
Regards
@wrighte wrote:.dcl added to allowed types. Good suggestion.
Maybe you should have considered user testing the new forum software? Who knows, one of them may have provided you with a useful set of allowed file extensions, such as .dcl. They may have also provided you with a wealth of other useful feedback about the forum software that you could have taken into account. They might even advised you to choose different software altogether, if they had just happened to notice in passing that this one sucks. That way, maybe you could have avoided inflicting this regurgitated dog's breakfast on your customers.
Just a thought.
Please get rid of graphic-image emoticons.
Given the common use of colons in AutoLisp functions, such as the command-name argument in (defun), and the fact that colons can also be used in other ways such as in variable names, it is really stupid that certain combinations of colons with other characters trigger dumb little faces. What do we need those for, on a forum like this? If people want to use emoticons in their message content outside code portions, I imagine they will settle for the old text-characters-only versions. 8^(
Yes, I have my "Emoticon type" set to "None," so when I'm Signed In, I don't see them. But even I sometimes check into the website and look at some things without necessarily signing in, and am therefore victimized by them. And anyone who isn't registered is out of luck, with no way to know what should go in the code there instead, unless they happen to know which emoticon represents which character combination [I just posted a Translator, to tide us over, and to soon become obsolete, I hope].
It wouldn't be so bad if, when content that includes them is copied and pasted into a plain-text editor like Notepad, the colon-and-character combinations were restored. But they're not -- they're just missing.
In my case, one account belongs to my employer (The Subscription login) and the other account (Forum) is my personal one.
However, the problem described is not a forum or an Autodesk issue. It's just the way browsers work with cookies.
I use one browser (Chrome) for accessing the forums, and another one (Firefox) for accessing the Subscription site. Both maintain their unique cookies and allow me to login to both sites with different credentials.
@Anonymous - Yeah, I know it's been 5 years and you've probably already figured this out 😉
Is it working now?
(defun C:foo () (do_something))
@rkmcswain wrote:
Is it working now?
That's not a valid test, since f is not one of the characters that trigger emoticons when following a colon. But here's a check on some that do, which [if they haven't taken my suggestion to eliminate that feature, and only when you're not signed in or have not disabled them in your preferences] will appear as emoticons:
:S
Now I have to sign out in order to see whether they do, since when signed in I have them disabled....
EDIT: And yes, they still do trigger emoticons under those circumstances, so the answer is No, it's not working now [assuming that by "working" you meant that they heeded my request and discontinued colon+character emoticon capability].
Good point, I thought I was still seeing these occasionally.
Now I have to sign out in order to see whether they do....
Or just copy and paste the URL into a "Private" (Firefox), "Incognito" (chrome) or.....[well, who cares about IE!] tab or window
(defun C:DaTest ()
(do_something)
(c:Onother one)
(S::Startup)
(Function:)
;;; I wonder if they work in code windows also? (defun C:DaTest () (do_something) (c:Onother one) (S::Startup) (Function:) )
@rkmcswain wrote:
;;; I wonder if they work in code windows also? ....
They do not show as emoticons inside the code window when the ones outside it do [at least not in Internet Explorer or Google Chrome]. That's good to know -- they still did back when I first dealt with this situation, so I'm glad it's been "fixed" at least inside code windows.
Looks like that happened sometime in 2012.
I'm going to add an entry to the community IdeaStation to turn them off globally as a default.
