Hi there, its the first time i am posting though im reviwing posts and much more long time and its really a great place to learn,
i am working on an new system to work with plans with pre-custom Blocks & Dynamic Blocks, , as in the finalizing stage, i have this case i need help in,
i have a block with multiple attributes , i want to copy the attributes values "AS FIELDS" to another different block, so the second one is always updated when i change the first one values, and i want to do it once,
i have a LISP that copy content as field but i have to click each attritube , and i have another LISP that copy all attributes with same tags from a block to another once and its perfect,but unfortiontly dont copy as fields value, just copy all once.
is there a way to combine these lisps or if simpler update the LISP that copy all block attributes to be copy as field all block attributes once
im attaching LISPS with all respect to whom wrote these lisps, and the cad file with both blocks i need to copy as field between,
I need to copy from the "DATA BLOCK" to the "DOORS" Dynamic block as fields all matching attributes,
Kindly and please assist me in these as i am still a junior in the LISPS functions and modifications
Solved by pbejse. Go to Solution.
Welcome to Autodesk Lisp Forum raghood. Try this
(defun C:MTB2 (/ ename enam data ss) ;;; pBe Dec2014 ;;; (while (not (progn (prompt "\nSelect Source Block:") (setq ename (ssget "_:S:E" '((0 . "INSERT") (66 . 1)))) ) ) (princ "\nInvalid or null selection") ) (cond ((and (setq enam (ssname ename 0)) (setq data (_FieldsVal enam t nil));<-- Get Mode & Fields mode (prompt "\n<<<Select blocks to process>>>") (setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1)))) (repeat (setq i (sslength ss)) (_FieldsVal (ssname ss (setq i (1- i))) nil data);<-- Set Mode ) ) ) ) (vla-regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport ) (princ) ) ;;; <<< pBe >>> ;;; ;;; Subfunction to Attribute Set/Get Fields/TEXT ;;; ;;; blk = The attribute block ;;; ;;; mode = T for Field Values ;;; ;;; = nil for String Values ;;; ;;; lst = If supplied, function in Set Mode ;;; ;;; = nil for Get Mode ;;; (defun _FieldsVal (blk mode lst / m f) (setq f (if mode (lambda (e) (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-ObjectId e)) ">%).TextString>%") ) (lambda (e) (vla-get-textstring e)) ) ) (mapcar '(lambda (at) (if lst (if (setq m (assoc (vla-get-tagstring at) lst)) (vla-put-textstring at (cadr m)) ) (list (vla-get-tagstring at) (f at)) ) ) (vlax-invoke (vlax-ename->vla-object blk) 'Getattributes) ) ) ;;; End of _FieldsVal ;;; (vl-load-com)
command: MTB2
You can use the sunfuction _FieldsVal even to get non field value.
(setq data (_FieldsVal enam nil nil));<-- that will give you the literal textsring value
HTH
Hi Pbejse,
Thanks alot & appreciate your quick reply and time given,
i tried to test the lisp but it keep showing this text and stops the command
" Command: MTB2
Select objects:
<<<Select blocks to process>>>Regenerating model.
Command: "
as if it jumps to other second command before i select any,
is it something i did wrong or it need to be modified ?
thanks again for your cooperation with me
i am attaching the LISP you sent to check,
@Anonymous wrote:
Hi Pbejse,
" Command: MTB2
Select objects:
Command: "
My bad dude,
change
to
(princ "\n<<<Select blocks to process>>>")
prompt evaluates to nil.
HTh
it is great now, it works perfectly and works just as i wanted and searched for it long time !
appreciated and many thanks
any advice from where i can start to study/understand lisp language,
i am able to do some tiny changes to writen ones not yet the whole text,
i am attaching the final lisp to share with others,
Thanks !
Thanks !
You are welcome raghood, I'm happy to help 🙂
As for the advice, just practice, practice, practice.... and read, read, read some more. it all starts with YOU, dont find time, make time. and ask questions here, forum members are more than happy to help you with your study.
I personally started here --> Afralisp
pBe
Hi I have almost the same situation but in my case, I need to select a Room number from an xref'd file and paste the value as field to my room tag.
Can the lisp CopyAsField be modified so that when I changed the room number in the xref, the tag also changes...
