Visual LISP, AutoLISP and General Customization
unknow command, using while
1 REPLY 1
robert06
189 Views, 1 Reply
Using these two lisps alternately, CAD does not recognize one or the other, it says 'unknown command' and executes then the one which was used first:
(defun c:os1 ()
    (command ".undo" "begin")
    (while (vl-cmdf "offset" ".25" pause pause "")
    (vl-cmdf "chprop" "l" "" "lt" "continuous" ""))
    (command "undo" "end")
    (princ)
(defun c:os2 ()
    (while (vl-cmdf "offset" ".2" pause pause "")
        (princ)
I must have done something wrong when I added repeating functionality, as they worked fine before that (below):
(defun c:os1 ()
    (command "offset" ".25" pause pause "")
    (command "chprop" "l" "" "lt" "continuous" "")
    (princ)
thanks!
1 REPLY 1
Kent1Cooper
in reply to: robert06
(defun c:os1 ()
    (princ)
The AutoLISP Reference says that (vl-cmdf) returns T, apparently regardless of anything the User does, which means the (while) loop won't ever end on its own.  But you could try a different way of going about it, that also doesn't require changing the linetypes of each resulting object individually:
(defun C:OS1 (/ celt)
  (command "_.undo" "_begin")
  (setq celt (getvar 'celtype)); save current value
  (command "_.offset" 0.25); leave User at selection prompt
  (while (> (getvar 'cmdactive) 0) (command pause)); let User keep offsetting things until they end it
  (setvar 'celtype celt); reset
  (command "_.undo" "_end")
  (princ)
It could probably use an error handler, to make sure CELTYPE gets reset if the User cancels or something.
Kent Cooper, AIA
”Boost
