guys can you please update this code and make the text output in leader format
and also this one is note working on dynamic block with strech and rotate parameter it display different name
; places name of block as text via pick (but i want it in leader format)
(defun C:blockn()
(setvar "cmdecho" 0)
(setq pt(cadr(entsel"\nSelect Block:")))
(setq e1(ssget pt))
(setq e2 (entget (ssname e1 0)))
(setq blname (cdr(assoc 2 e2)))
(setq pt1 (getpoint"\nSelect point for block title:"))
(command "text" pt1 "" 0 blname)
Solved by hmsilva. Go to Solution.
Hi olbapxpablo,
maybe something like this:
(defun c:demo (/ *error* echo name obj osm pt pt1 ss) (defun *error* (msg) (if echo (setvar 'CMDECHO echo)) (if osm (setvar 'OSMODE osm)) (cond ((not msg)) ((member msg '("Function cancelled" "quit / exit abort"))) ((princ (strcat "\n** Error: " msg " ** "))) ) (princ) ) (if (and (setq echo (getvar 'CMDECHO)) (setvar 'CMDECHO 0) (setq osm (getvar 'OSMODE)) (setvar 'OSMODE 512) (setq pt (getpoint "\nSelect a Block to put name in a Leader: ")) (setvar 'OSMODE osm) (setq ss (ssget pt '((0 . "INSERT")))) (setq obj (vlax-ename->vla-object (ssname ss 0))) (setq pt1 (getpoint pt "\nPosition of Leader text: ")) ) (progn (setq name (if (vlax-property-available-p obj 'effectivename) (vla-get-effectivename obj) (vla-get-name obj) ) ) (command "_.leader" "_NONE" pt "_NONE" pt1 "" name "") ) (prompt "\nNot a Block!") ) (*error* nil) (princ) )
Hope that helps
Henrique
this is what i wanted , thank you hmsilva
adding 2nd pickpoint in leader is possible?
You're welcome, olbapxpablo!
Try
(defun c:demo (/ *error* echo name obj osm pt pt1 pt2 ss) (defun *error* (msg) (if echo (setvar 'CMDECHO echo)) (if osm (setvar 'OSMODE osm)) (cond ((not msg)) ((member msg '("Function cancelled" "quit / exit abort"))) ((princ (strcat "\n** Error: " msg " ** "))) ) (princ) ) (if (and (setq echo (getvar 'CMDECHO)) (setvar 'CMDECHO 0) (setq osm (getvar 'OSMODE)) (setvar 'OSMODE 512) (setq pt (getpoint "\nSelect a Block to put name in a Leader: ")) (setvar 'OSMODE osm) (setq ss (ssget pt '((0 . "INSERT")))) (setq obj (vlax-ename->vla-object (ssname ss 0))) (setq pt1 (getpoint pt "\nSecond leader point: ")) (setq pt2 (getpoint pt1 "\nPosition of Leader text: ")) ) (progn (setq name (if (vlax-property-available-p obj 'effectivename) (vla-get-effectivename obj) (vla-get-name obj) ) ) (command "_.leader" "_NONE" pt "_NONE" pt1 "_NONE" pt2 "" name "") ) (prompt "\nNot a Block!") ) (*error* nil) (princ) )
Henrique
@olbapxpablo wrote:
sorry for too much request
can you please also do a same concept but instead of block name it take the att def ?
thank you very much in advance
You're welcome, olbapxpablo.
Attribute TAG or VALUE?
Henrique
Try:
(defun c:demo (/ *error* atts echo obj osm pt pt1 pt2 ss val) (defun *error* (msg) (if echo (setvar 'CMDECHO echo)) (if osm (setvar 'OSMODE osm)) (cond ((not msg)) ((member msg '("Function cancelled" "quit / exit abort"))) ((princ (strcat "\n** Error: " msg " ** "))) ) (princ) ) (if (and (setq echo (getvar 'CMDECHO)) (setvar 'CMDECHO 0) (setq osm (getvar 'OSMODE)) (setvar 'OSMODE 512) (setq pt (getpoint "\nSelect a Block to put Attribute Value in a Leader: ")) (setvar 'OSMODE osm) (setq ss (ssget pt '((0 . "INSERT")(66 . 1)))) (setq obj (vlax-ename->vla-object (ssname ss 0))) (vlax-property-available-p obj 'Hasattributes) (setq pt1 (getpoint pt "\nSecond leader point: ")) (setq pt2 (getpoint pt1 "\nPosition of Leader text: ")) ) (progn (setq atts (vlax-invoke obj 'Getattributes)) (setq val (vla-get-TextString (car atts))) (command "_.leader" "_NONE" pt "_NONE" pt1 "_NONE" pt2 "" val "") ) (prompt "\nNot a Block with Attributes!") ) (*error* nil) (princ) )
Henrique
