Hello All,
I have the following developed.
(command "ucs" "World")
(setq CVPort (getvar "cvport"))
(setq VPEnt (ssget "X" (list (cons 0 "VIEWPORT")(cons 69 CVPort))))
(setq VPEnt (ssname VPEnt 0))
(setq VPEnt (entget VPEnt))
(setq FrontClip (cdr (assoc 43 VPEnt)))
(setq GetDirection (getvar "viewdir"))
(setq GetDirectionX (atof (rtos (car GetDirection) 2 8)))
(setq GetDirectionY (atof (rtos (cadr GetDirection) 2 8)))
(setq GetDirectionZ (atof (rtos (caddr GetDirection) 2 8)))
(cond
((and (< GetDirectionX 0)(= GetDirectionY 0)(= GetDirectionZ 0))(command "ucs" "Z" "270" "ucs" "X" "90"))
((and (> GetDirectionX 0)(= GetDirectionY 0)(= GetDirectionZ 0))(command "ucs" "Z" "90" "ucs" "X" "90"))
((and (= GetDirectionX 0)(< GetDirectionY 0)(= GetDirectionZ 0))(command "ucs" "X" "90"))
((and (= GetDirectionX 0)(> GetDirectionY 0)(= GetDirectionZ 0))(command "ucs" "Z" "180" "ucs" "X" "90"))
((and (= GetDirectionX 0)(= GetDirectionY 0)(> GetDirectionZ 0)))
((and (= GetDirectionX 0)(= GetDirectionY 0)(< GetDirectionZ 0))(command "ucs" "Z" "270" "ucs" "X" "90"))
(T(Alert "Your view in this viewport is not a true plan view!")(command "undo" "Back")(exit))
(setq MoveZ (list 0.0 0.0 FrontClip))
(command "ucs" "New" MoveZ)
In theory, this should work, but for some reason it's not. Do I need a target camera calculation or something?
Solved by kpennell. Go to Solution.
So I figured out that the front clipping plane location is a calculation of the Target Point (X or Y or Z depending on which way you're looking), and the "FrontZ".
So if anyone wants to set their UCS to the front in "true" plan-type views, here is my contribution. Organized so I can understand it 🙂
(setq TargetX (car (cdr (assoc 17 VPEnt))))
(setq TargetY (cadr (cdr (assoc 17 VPEnt))))
(setq TargetZ (caddr (cdr (assoc 17 VPEnt))))
(cond
((and (< GetDirectionX 0)(= GetDirectionY 0)(= GetDirectionZ 0)(< (- TargetX FrontClip) 0))
(setq MoveZ (list 0.0 0.0 (- (abs (- TargetX FrontClip)) 0.0001))))
((and (< GetDirectionX 0)(= GetDirectionY 0)(= GetDirectionZ 0)(> (- TargetX FrontClip) 0))
(setq MoveZ (list 0.0 0.0 (- (* (abs (- TargetX FrontClip)) -1) 0.0001))))
((and (> GetDirectionX 0)(= GetDirectionY 0)(= GetDirectionZ 0)(> (+ TargetX FrontClip) 0))
(setq MoveZ (list 0.0 0.0 (- (abs (+ TargetX FrontClip)) 0.0001))))
((and (> GetDirectionX 0)(= GetDirectionY 0)(= GetDirectionZ 0)(< (+ TargetX FrontClip) 0))
(setq MoveZ (list 0.0 0.0 (- (* (abs (+ TargetX FrontClip)) -1) 0.0001))))
((and (= GetDirectionX 0)(< GetDirectionY 0)(= GetDirectionZ 0)(< (- TargetY FrontClip) 0))
(setq MoveZ (list 0.0 0.0 (- (abs (- TargetY FrontClip)) 0.0001))))
((and (= GetDirectionX 0)(< GetDirectionY 0)(= GetDirectionZ 0)(> (- TargetY FrontClip) 0))
(setq MoveZ (list 0.0 0.0 (- (* (abs (- TargetY FrontClip)) -1) 0.0001))))
((and (= GetDirectionX 0)(> GetDirectionY 0)(= GetDirectionZ 0)(< (+ TargetY FrontClip) 0))
(setq MoveZ (list 0.0 0.0 (- (* (abs (+ TargetY FrontClip)) -1) 0.0001))))
((and (= GetDirectionX 0)(> GetDirectionY 0)(= GetDirectionZ 0)(> (+ TargetY FrontClip) 0))
(setq MoveZ (list 0.0 0.0 (- (abs (+ TargetY FrontClip)) 0.0001))))
((and (= GetDirectionX 0)(= GetDirectionY 0)(< GetDirectionZ 0)(< (- TargetZ FrontClip) 0))
(command "ucs" "Y" "180")
(setq MoveZ (list 0.0 0.0 (- (abs (- TargetZ FrontClip)) 0.0001))))
((and (= GetDirectionX 0)(= GetDirectionY 0)(< GetDirectionZ 0)(> (- TargetZ FrontClip) 0))
(setq MoveZ (list 0.0 0.0 (- (* (abs (- TargetZ FrontClip)) -1) 0.0001))))
((and (= GetDirectionX 0)(= GetDirectionY 0)(> GetDirectionZ 0)(< (+ TargetZ FrontClip) 0))
(setq MoveZ (list 0.0 0.0 (- (* (abs (+ TargetZ FrontClip)) -1) 0.0001))))
((and (= GetDirectionX 0)(= GetDirectionY 0)(> GetDirectionZ 0)(> (+ TargetZ FrontClip) 0))
(setq MoveZ (list 0.0 0.0 (- (abs (+ TargetZ FrontClip)) 0.0001))))
(T(Alert "Your view in this viewport is not a true plan view!"))
(setq ViewAngle (/ (* (getvar "viewtwist") 180) pi))
(command "ucs" "Z" (* ViewAngle -1))
(setq OldOsnap (getvar "osmode"))
(setvar "osmode" 0)
(setvar "osmode" OldOsnap)
Use it abuse it as you see fit.
