Visual LISP, AutoLISP and General Customization
turn on/off annotative
17 REPLIES 17
Message 1 of 18
Moshe-A
2892 Views, 17 Replies
Hi Guys,
when a text is selected, in properties palette the Annotative field can be turned on/off  - how can i do it programatically?
activex doesn't not have a propertiy for it. i presume it is in xrecords but could not find it.
thanks in advanced
Moshe
17 REPLIES 17
Message 2 of 18
pbejse
in reply to: Moshe-A
@Moshe-A wrote:
Hi Guys,
thanks in advanced
Moshe
The most simple way i can think of is:
(command "_chprop" (ssget "_X" '((0 . "MTEXT,TEXT")(410 . "MODEL"))) "" "A" "No" "")
(command "_chprop" (ssget "_X" '((0 . "MTEXT,TEXT")(410 . "MODEL"))) "" "A" "Yes" "")
(command "_chprop" entity "" "A" "Yes" "")
Message 3 of 18
Moshe-A
in reply to: pbejse
Ok but if it's an attribute?
Message 4 of 18
pbejse
Good question Moshe-A. never thought of that Smiley Very Happy,
Message 5 of 18
Moshe-A
in reply to: pbejse
Sorry by mistake i pressed 'Accept as Solution'
On my current application have some attribute blocks that are placed in at 1X1 scale but the text style is annotative. i would like to give the user an option to turn off the annotation when they are 100% sure these blocks are in the right scale (and it won't be changed in future)
Thank you very much for your help
Moshe
Message 6 of 18
pbejse
Moshe
No worries. i already took care of that.
I'll have a look see-later  and see what i can dig up.
Message 7 of 18
hmsilva
Moshe,
to remove anotatividade to a text
(defun c:test (/ ed)
  (setq ed (entget (car (entsel)) '("AcadAnnotative")))
  (setq	ed (subst (list	-3
			(list "AcadAnnotative"
			      '(1000 . "AnnotativeData")
			      '(1002 . "{")
			      '(1070 . 1)
			      '(1070 . 0)
			      '(1002 . "}")
		  (assoc -3 ed)
		  ed
  (entmod ed)
  (princ)
hope that helps
Henrique
Message 8 of 18
Moshe-A
in reply to: hmsilva
Henrique,
it looks like the ATTRIB does not holds this xdata so it must be in ATTDEF?
i thought i could turn each attrib annotation to off?
Message 9 of 18
hmsilva
Moshe,
just try
(setq ed (entget (car (nentsel)) '("AcadAnnotative")))
Henrique
Message 10 of 18
Moshe-A
Henrique,
Yes Smiley Very Happy you are right.
thank you very much for this help
Moshe
Message 11 of 18
hmsilva
Moshe,
just for testing
(defun c:test (/ ed blk att)
  (setq blk (car (entsel "\nSelect a block to remove Annotative prop from text: ")))
  (setq att blk)
  (if (assoc 66 (entget blk))
    (while (= (cdr (assoc 0 (entget (setq att (entnext att))))) "ATTRIB")
      (setq ed (entget att '("AcadAnnotative")))
			    (list "AcadAnnotative" '(1000
						     "AnnotativeData"
						    ) '(1002 . "{")
				  '(1070 . 1) '(1070 . 0) '(1002 . "}"))
		      (assoc -3 ed)
		      ed
      (entmod ed)
  (princ)
hope that helps
Henrique
Message 12 of 18
hmsilva
You're welcome, Moshe
glad i could help
Henrique
Message 13 of 18
Moshe-A
Henrique & pbejse
here is an update on this case
althought the disable for the annotative attribute is done the behaviour of autocad is weird
some time changing the annotation scale does have no effect on them some time it does
it look like autocad remembers the previous annotation scale that were apply to those objects
and do change the scale even if annotative is off  and it may do this with an unmatched scale to the
current annotation selected scale
Moshe
Message 14 of 18
hmsilva
Moshe,
I can't reproduce that behavior, if possible attach a sample dwg
Henrique
Message 15 of 18
Moshe-A
sorry henrique
was tired last night, i will send it tonight
moshe
Message 16 of 18
Moshe-A
Ok - here it is
i have disable annotative in all 3 attributes
did more checks and it look like autocad do remember the prevoius scales that were applied before turnning annotative off and restore these scale as you change annotation scale
thought i would delete those scale from block (or attributes) but could not find them there
maybe this happends due this is too complex object? (e.g dynamic annotative block with attributes?)
thanks
moshe
Message 17 of 18
Moshe-A
switched to google chrome - hope this will upload the file
yes!!! Smiley Very Happy
Message 18 of 18
hmsilva
Moshe,
also can't find where is stored the annotative property after being disabled...
I'll keep looking...
Henrique
”Boost
