I have a trouble with rectang command after removing reluxcad application (cad add on). Now after invoking rectang I receive alert described in a pictures. How can I remove reluxcad rectang traces?
Solved by igal1971. Go to Solution.
Hi igal1971,
I never used this plugin, but how did you uninstall the reluxcad, was via reluxcad uninstaler?
Did you removed all eelux installation directory after uninstaling?
Henrique
Hi Henrique! How are you?
Reluxcad was uninstalled properly without any "trouble" messages via windows uninstaller.. i think the source of problem in the windows registry file.. what your appinion about it?
Hi igal1971, I'm ok thank you.
I was referring the plugin uninstaler, not the windows...
Start->all programs->ReluxSuite->tools->"Uninstall Relux"
it should remove all registry keys, and reverse all changes made by the plugin... should...
Try
Command: !rectang
What is the return?
Henrique
Thank a LOT Henrique!
After the all reluxcad registry keys were removed totaly (it was very complicate work, beleve me) regtang started to work as SINGLE regular function
