I am not sure what I changed in the settings of my Autocad (2011). But today whenever I run a lisp program, all of the dialog boxes open up for all commands called in the lisp that do not have the "-" infront of them. I have tried toggling the CMDDIA variable to "0" and this still has no effect.
Is there some other variable that I could have changed on accident?
The commands in the lisp rotuine that get called are "LAYER" and "STYLE" if that helps any.
Thank you.
Jona
Try placinmg a hyphen in front of layer or style
i.e. (command "-layer"..... or (command "-style" ...
hth
southie
I realize this would fix it, but I have dozens of lisp routines that worked on friday, and I am not sure what I did inbetween that they all no longer work becuase of this dialog box issue.
maybe this system variable
FILEDIA
Suppresses display of file navigation dialog boxes.
I tried with all ATTDIA, CMDDIA, and FILEDIA variables set to 0 and it still did it.
I finally decided to uninstall and reinstall autocad to fix the problem since it was taking so long to figure it out.
This solved my problem. Thanks for my help. Hopefully it doesnt happen again.
