Hello All,
I'm hoping someone can tell me what I'm doing wrong in the code below; I feel like it is something silly that I'm just not catching:
(defun HAPPY ()
(setq cmdecho (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(setq sspoly (ssget "A" '((0 . "LWPOLYLINE"))))
(setq sscirc (ssget "A" '((0 . "CIRCLE"))))
(setq ssline (ssget "A" '((0 . "LINE"))))
(setq enpoly (ssname sspoly 0))
(setq enpoly (entget enpoly))
(setq enpoly (assoc 10 enpoly))
(setq pt (list (cadr enpoly) (caddr enpoly)))
(setq filename (getvar "dwgname"))
(setq file (strcat "S:/1. Design Assist/2112 PENN AVENUE/0.1 LBFs Experimental Folder/Outputs/" filename))
(command "wblock" file "" pt "all" "")
(setvar "CMDECHO" cmdecho)
(setvar "tilemode" 1)
(command "layer" "set" "FIN PATTERNS" "OFF" "*" "n" "FREEZE" "*" "THAW" "DIM" "ON" "DIM")
(command)
(HAPPY)
I got this code (and script) to work last week in a SCRIPT (.scr) to block out a bunch of different pattern glass fab tickets, but now it doesn't work. ScriptPro says "DONE", but when I run the script in an individual drawing... The WBLOCK line spits out a nil and the objects that should be blocked out remain in the drawing.
To be clear, it functions perfect as a LISP routine. However, it does not complete the WBLOCK line when I import into a SCRIPT. Also, there are no files in the target folder (WBLOCK command won't spit out the "Do you wish to replace" dialog. I will eventually add a couple vl lines to automatically delete the file before the WBLOCK to prevent the message from appearing.
Thanks in advance everyone. This is really frustrating me.
Frost
Since you have spaces in the folder name, perhaps try surrounding the file name with quotes:
(setq file (strcat "\"S:/1. Design Assist/2112 PENN AVENUE/0.1 LBFs Experimental Folder/Outputs/" filename "\""))
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales |Exchange App Store
Thanks Paul, but unfortunately it still does not work. When I run the script, the variables and my defined function HAPPY are not processed. After I run the script on one file (using the command SCRIPT, not ScriptPro), HAPPY is not defined; which means the variables and selection sets are not defined either.
What am I overlooking? This is driving me nuts that it's not working all of the sudden.
What if you save the lisp code into a file called HAPPY.lsp
Then in the Script file use the following line to load the script file:
(load"HAPPY")
Then activate the function with this line:
(HAPPY)
Paul... Thank you! Success!
I was trying every work around in the book trying to get it to work, but that is the one I needed. Thank you my friend.
glad that worked out for you.
Well... Just found out that it hasn't exactly. When I run the script in AutoCAD, it's fine. But, when I use it in ScriptPro... It says it's "Done," but it didn't save the changes. I added a qsave to the end of the script and no luck.
Why is my ScriptPro acting like this? Shouldn't it read the script file the same way?
Hopefully someone with ScriptPro experience can chime in here...
Maybe it's only a copy/paste glitch, and your file as applied doesn't have this problem, but I don't see a closing right parenthesis for the (defun) function in the code in the first message. It looks like it ought to have one after the last (command) function and before the (HAPPY) that invokes what was just defined, but what it was trying to define won't be without closing the defining function.
[EDIT -- Never mind; I see it farther up. I was figuring the stuff near the bottom was part of the function definition, but apparently not. I thought deleting my Reply would be one of my Options, but at the moment it's not offering that....]
Thanks for the reply Kent, but I think you may have missed the closing bracket just a few lines higher (see bold & italiced below):
(defun HAPPY ()
(command)
(HAPPY)
I'm going to try to run it on my desktop at home, maybe something is faulty in the software? Using Paul's suggestion, the script works, but does not save. Maybe it's still not processing the AutoLISP codes within the commands? Any chance this is an AutoCAD variable that got changed?
