I am looking to develop a lisp routine to help out trimming out our panel joints, it is a task that we perform everyday and the "trim" command takes a lot of time. In the attached image the cyan box on the left is how they start with two sets of intersecting polylines, the box on the right is how we would like them after the routine. Currently we have to trim selecting all edges and then zoom in and only select the area inbetween the lines, i would like to bea able to make a selection window roughly the size of the cyan box over the entire joint/intersection. There wont always be 4 intersecting lines but at least: one line with two parallel lines terminating into the continuous line. In the current trim command when i select all edges and try to window around the joint, it will give the opposite result of what i am wanting, leaving only a small "box" made up of only the portions of the lines in between.
Solved by Gary_J_Orr. Go to Solution.
Gary,
I also wanted to follow up now that I have had some time to test your routine.
It is working great when I tested it with various scenarios in AutoCAD 2015.
I think that I will make a follow up on my blog post and simply point people to your routine especially if they are using 2015.
Thanks for sharing your great work,
~Greg
@Anonymous wrote:
I realized that there are a few places in which one might not like the results and decide that they want to clean that intersection up manually, but my last version is "all or nothing"
Nicely coded, Garry.
Henrique
