I want to write content of variables to a text file but I should have conversion function for variables.
for example
(setq a 123); a is an integer type, contetnt of a is 123
so I should use (itoa a) to get "123" as a string and then I can write it to text file.
but what about another type of variables?
(defun ToString ( a / result) (setq result "") (cond ((= (type a) 'ENAME) (progn (setq result "Entity names"))) ((= (type a) 'EXRXSUBR) (progn (setq result "External ObjectARX applications"))) ((= (type a) 'FILE) (progn (setq result "File descriptors"))) ((= (type a) 'INT) (progn (setq result (itoa a))));;"Integers" ((= (type a) 'LIST) (progn (setq result "Lists"))) ((= (type a) 'PAGETB) (progn (setq result "Function paging table"))) ((= (type a) 'PICKSET) (progn (setq result "Selection sets"))) ((= (type a) 'REAL) (progn (setq result (rtos a 2 3))));;"Floating-point numbers" ((= (type a) 'SAFEARRAY) (progn (setq result "Safearray"))) ((= (type a) 'STR) (progn (setq result a)));;"Strings" ((= (type a) 'SUBR) (progn (setq result "Internal AutoLISP functions"))) ((= (type a) 'SYM) (progn (setq result "Symbols"))) ((= (type a) 'VARIANT) (progn (setq result "Variant"))) ((= (type a) 'USUBR) (progn (setq result "User-defined functions loaded from LISP source files"))) ((= (type a) 'VLA-object) (progn (setq result "ActiveX objects"))) ) Result )
@aqdam1978 wrote:Hi,
for example
Would you want the "value" of the variable to write to string?
for example (setq a '(1.2 2.5 0.0))
(type a) = LIST
write to string --- > "(1.2 2.5 0.0)" and not "lists" as you have shown on your code?
@aqdam1978 wrote:yes, exactly, because I can't write any variables in a text file except string variables!
Its easy. waht you need is an association list .
NOT sure why you need to write to string the "other types" but you may need to add an function to evaluate the variable value and convert it to a string like the one on your sample
(INT (itoa a))
(eval.. will evaluate the second element
(defun ToString (a / result) (eval (cadr (assoc (type a) '((ENAME "Entity names") (EXRXSUBR "External ObjectARX applications") (FILE "File descriptors") (INT (itoa a)) (LIST (vl-princ-to-string a)) (PAGETB "Function paging table") (PICKSET "Selection sets") (REAL (rtos a 2 3)) (SAFEARRAY "Safearray") (STR a) (SUBR "Internal AutoLISP functions") (SYM "Symbols") (VARIANT "Variant") (USUBR "User-defined functions loaded from LISP source files") (VLA-object "ActiveX objects")))) ) )
As for the other types, i' leave that to you to figure out the functions.
HTH
EDIT: That was you question, silly me... I woiuld love to play but you need to give an example for each type then i can point you in the right direction.
Hi Pbejse,
you are hero!
I just want to have general function to convert all types of variable to string.
I call it ToString.
for exaple see the "ToString" function usage in this code:
(defun c:GetSystemInfo(/ item meth1 meth2 process wmi fn des) (defun ToString (a) (eval (cadr (assoc (type a) '((ENAME "Entity names") (EXRXSUBR "External ObjectARX applications") (FILE "File descriptors") (INT (itoa a)) (LIST (vl-princ-to-string a)) (PAGETB "Function paging table") (PICKSET "Selection sets") (REAL (rtos a 2 3)) (SAFEARRAY "Safearray") (STR a) (SUBR "Internal AutoLISP functions") (SYM "Symbols") (VARIANT "Variant") (USUBR "User-defined functions loaded from LISP source files") (VLA-object "ActiveX objects")))) ) ) (defun lister(val / it) (vlax-for it val (if (vlax-get it 'value) (write-line (strcat (vlax-get it 'name) " : " (ToString (vlax-get it 'value))) des) );;if );;vlax ) (vl-load-com) (setq fn "D:\\SystemInfo.txt") (setq des (open fn "w" )) (setq WMI (vlax-create-object "WbemScripting.SWbemLocator")) (setq meth1 (vlax-invoke WMI 'ConnectServer nil nil nil nil nil nil nil nil)) (write-line "------------------------------------------------------------" des) (foreach process (list "BIOS" "Processor" "VideoController" "SoundDevice" "CDROMDrive" "OperatingSystem" "ComputerSystem" "PhysicalMemory" "DiskDrive") (setq meth2 (vlax-invoke meth1 'ExecQuery (strcat "Select * from Win32_" Process))) (write-line (strcat "<<< features of " process " >>>:\n------------------------------------------------------------") des) (vlax-for item meth2 (lister (vlax-get item 'Properties_)) (lister (vlax-get item 'Qualifiers_)) (write-line "------------------------------------------------------------" des) ) );;foreach (close des) (mapcar 'vlax-release-object (list meth1 meth2 wmi)) (startapp "Notepad" fn) (princ) )
Thank you for all of your helps and supports.
Abbas
it that case you dont need a fancy sub to convert all the values to string
vl-princ-to-string will suffice
(defun lister (val file / it) (vlax-for it val (if (vlax-get it 'value) (write-line (strcat (vlax-get it 'name) " : " (vl-princ-to-string (vlax-get it 'value))) file) );;if );;vlax )
(vlax-for item meth2 (lister (vlax-get item 'Properties_) des) (lister (vlax-get item 'Qualifiers_) des) (write-line "------------------------------------------------------------" des) )
HTH
