It's been too long since I created one of these for Toolbars. I need a macro that will insert and explode a block. I just need the block's content, not the block itself. I can create a maco to explode a block with no path, but can't remember how to include the "*" in a file with a folder path to explode the block while its being inserted. Because of spaces in the file name, quotes (") must be around the path.
Solved by hmsilva. Go to Solution.
@randy.brockington wrote:It's been too long since I created one of these for Toolbars. I need a macro that will insert and explode a block. I just need the block's content, not the block itself. I can create a maco to explode a block with no path, but can't remember how to include the "*" in a file with a folder path to explode the block while its being inserted. Because of spaces in the file name, quotes (") must be around the path.
eg
^c^c_-insert;"*c:/test/blk1.dwg"
hope that helps
Henrique
If you are inserting block from Tool Palette like your title suggests, just right click on the block image. Go to Properties. There is an option to explode on insertion.
