I'm getting closer on this but now it says that i have too many arguments. I copied this code in from another routine that i found online. Can anyone dicipher this?
This is the message i get when i check the text:
; error: too many arguments: (IF (OR ( ... ) ( ... ) ( ... ) ... ) (SETQ FOLDR&FLNAME_2COPY ( ... )) (IF ( ... ) ( ... )) ... )
Here is my code:
(IF
(or
(member
(strcase (GETVAR "PROJECTNAME"))
'("CDG")
); member
(= (strcase (GETVAR "ORIENTATION")) "HORIZONTAL")
(= (strcase (GETVAR "LOCATION")) "BOTTOM")
(= (strcase (GETVAR "SHTSIZE")) "8.5X11")
); or
(setq foldr&flname_2copy
'("H:\\Overlays\\CDG\\" ;<<< input here folder path of source
"skhb.dwg" ;<<< input here filename to be copied
) ;_ end_setq
(if (findfile (apply 'strcat foldr&flname_2copy))
(if (findfile (strcat (getvar "dwgprefix") (cadr foldr&flname_2copy)))
(alert "\n File Exists in Destination Folder")
(progn
(setq curr_dir (strcat (getvar "dwgprefix") (cadr foldr&flname_2copy)))
(vl-file-copy (apply 'strcat foldr&flname_2copy) curr_dir)
(prompt (strcat (strcase (cadr foldr&flname_2copy))
" copied to "
(strcase (getvar "dwgprefix"))
) ;_ end_strcat
) ;_ end_prompt
) ;_ end_progn
) ;_ end_if
); if
(alert "\n Source File Does not Exist")
) ;_ end_if projectname
(princ)
Something like this perhaps
(IF (or (member (strcase (GETVAR "PROJECTNAME")) '("CDG") ) ; member (= (strcase (GETVAR "ORIENTATION")) "HORIZONTAL") (= (strcase (GETVAR "LOCATION")) "BOTTOM") (= (strcase (GETVAR "SHTSIZE")) "8.5X11") ) ; or (progn;; <<<< (setq foldr&flname_2copy '("H:\\Overlays\\CDG\\";<<< input here folder path of source "skhb.dwg";<<< input here filename to be copied ) ) ;_ end_setq (if (findfile (apply 'strcat foldr&flname_2copy)) (if (findfile (strcat (getvar "dwgprefix") (cadr foldr&flname_2copy))) (alert "\n File Exists in Destination Folder") (progn (setq curr_dir (strcat (getvar "dwgprefix") (cadr foldr&flname_2copy)) ) (vl-file-copy (apply 'strcat foldr&flname_2copy) curr_dir) (prompt (strcat (strcase (cadr foldr&flname_2copy)) " copied to " (strcase (getvar "dwgprefix")) ) ;_ end_strcat ) ;_ end_prompt ) ;_ end_progn ) ;_ end_if (alert "\n Source File Does not Exist") ); if );; progn <<<< ) ;_ end_if projectname
HTH
Henrique
Again, if I'm reading it right, I think this is the adjustment you need to make. An (if) expression can accept a maximum of three arguments: a 'test' expression, a 'then' expression [if the test returns anything other than nil], and [optionally] an 'else' expression [if the test returns nil]. As you have it:
(IF ; [outermost]
(or ; the 'test' expression
(member
'("CDG")
); member
); end or and 'test' for outermost (if)
(setq foldr&flname_2copy ; the 'then' expression for the outermost (if)
); end quoted list
) ;_ end_setq
(if (findfile (apply 'strcat foldr&flname_2copy)); the 'else' expression for the outermost (if) [when the test returns nil] is the mid-level (if)
(if (findfile (strcat (getvar "dwgprefix") (cadr foldr&flname_2copy))); the 'then' expression for the mid-level (if) is the innermost (if)
(alert "\n File Exists in Destination Folder"); the 'then' expression for the innermost (if)
(progn ; the 'else' expression for the innermost (if)
(prompt
" copied to "
) ;_ end_strcat
) ;_ end_prompt
) ;_ end_progn and 'else' expression for innermost (if)
) ;_ end_if [innermost] and 'then' expression for mid-level (if)
); end if [mid-level] and 'else' expression for outermost (if), which is the last argument it can accept, therefore:
(alert "\n Source File Does not Exist"); this becomes one more argument than the outermost (if) can accept,
; but given what it says, I think it should be the 'else' expression for the mid-level (if)
) ;_ end_if projectname [outermost]
(princ)
So I think the end should be re-arranged:
(alert "\n Source File Does not Exist"); 'else' expression for the mid-level (if) [moved up one line]
); end if [mid-level] and 'else' expression for outermost (if) now after the (alert)
(princ)
Thanks Kent,
That works now. At least it works in the text editor. I will have to wait till i get to the office to test it in the real world. I'm sure theres some more tweaking to do but im getting closer & closer thanks to everyone who has giving me help. I would never have gotten this far if it wasnt for you guys. Do you think i will have to do the next part as a new routine? what i want to do is to attach the titleblock as an xref once the correct one is copied to the current directory. I want sure if it was possible to do this as one routine or not or would it be too complicated?
