Visual LISP, AutoLISP and General Customization
toggle drawing units
4 REPLIES 4
Cinimod89
845 Views, 4 Replies
Is there a way of opening existing cmds in the visual lisp editor and edit them to do something else? I'd like to set up a lisp where 'uu' would switch the drawing units from decimal to architectural units and hittng 'uu' again would switch it back.
4 REPLIES 4
_Tharwat
in reply to: Cinimod89
Try this routine but you need to hit F2 after running the code .
(defun c:uu nil
  (if *decimal*
    (progn
      (command "_.-units" "2" "" "" "" "" "")
      (setq *decimal* nil)
    (progn
      (command "_.-units" "4" "" "" "" "" "")
      (setq *decimal* t)
  (princ)
Lee_Mac
Another:
(defun c:uu nil
    (setvar 'lunits (- 6 (getvar 'lunits)))
    (princ)
Assumes units are already set to either Decimal or Architectural.
Lee
dgorsman
To add to the other comments:  I'd suggest naming the function something more descriptive so it won't clash with something else.  You can always map "UU" to the command in the PGP file, which is much easier to edit than LISP files.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
stevor
And Lee's can also be: ; toggle LUnits of 2 or 4 (defun c:TU ( ) (princ " Toggle LUnits: ") (setvar 'lunits (if (= (getvar 'lunits) 2) 4 2)) (princ (if (= (getvar 'lunits) 2) "Decimal." "Arch.") ) (princ) ) The command name is almost as quick; or any name used if put into the menu/CUI. And as a lisp, it is easy to change.
S
”Boost
