this will not redraw obj when I exit the command if I hit ESC IT WILL
(DEFUN C:CHF ()
(command "undo" "BE")
(setq osm (getvar "osmode"))
(setvar "osmode" 0)
(defun *error* (msg)
(if objs (foreach pol objs (redraw pol 4)))
(cond ((not msg)) ; Normal exit
((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit)
((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it
(princ)
(setq obj (entsel "\nSelect object:"))
(setq pol (car obj))
(setq pt (cadr obj))
(setq ptn (osnap pt "NEA"))
(setq pt (vlax-curve-getClosestPointTo (vlax-ename->vla-object pol) pt))
(setq objs (cons pol objs))
(redraw pol 3)
(foreach obj1 '(a)
(while (setq obj1 (entsel "\nSelect part of object to change: "))
(setq pt1 (cadr obj1))
(setq pol1 (car obj1))
(setq pt1n (osnap pt1 "NEA"))
(setq int (vlax-invoke
(vlax-ename->vla-object (car obj))
"intersectwith"
(vlax-ename->vla-object (car obj1))
acExtendBoth)
(setq int1 (list (car int) (cadr int) (caddr int)))
(setq int2 (cdddr int))
(cond
((= ang1 ang2 ang3)
(command "line" end1 int1 "")
((and(= ang2 ang3)(/= ang1 ang2)(/= ang1 ang3))
(command "line" end1 int2 "")
((and(= ang1 ang2)(/= ang3 ang1)(/= ang3 ang2))
(command "line" end2 int2 "")
((and(= ang1 ang3)(/= ang2 ang1)(/= ang2 ang3))
(command "line" end2 int1 "")
(if (null a)
(command cancel)
(setvar "osmode" 183)
(command "undo" "E")
(princ)
(DEFUN C:CHF ()
(princ)
)(*error* nil) (princ)
