Visual LISP, AutoLISP and General Customization
Text screen
5 REPLIES 5
teflon
512 Views, 5 Replies
Text screen
Running some lisps or scripts an extra text screen pops up!
Why?
I can´t see anything in the codes causing that!
5 REPLIES 5
bart_van_tuyl
in reply to: teflon
Describe the text that popsup, could be an array of things...
teflon
in reply to: bart_van_tuyl
If I run this lisp an extra text screen will pop up!
mracad
in reply to: teflon
the (textpage) shows the text screen (same as when you hit the F2 key) the (graphscr) closes the text screen He is using the to make it easier to see the styles available.
teflon
in reply to: mracad
Thanks!
I was looking for something like TEXTSCR, an Autocad command.
Because I recognized GRAPHSCR among the codes.
TEXTSCR opens a new text screen same as F2 you mentioned.
But what is the function of Graphscreen???
I have got two screens.
marko_ribar
in reply to: teflon
@Anonymous wrote:
Thanks!
(graphscr) function is used to minimize pop-up of (textscr) function... It's just the opposite...
Marko Ribar, d.i.a. (graduated engineer of architecture)
”Boost
