Visual LISP, AutoLISP and General Customization
Text DwgName XDATA
1 REPLY 1
aqdam1978
395 Views, 1 Reply
Text DwgName XDATA
Hi friends,
I want to add some lisp command to "ACAD2013DOC.LSP" file that causes:
every time I opened a drawing, there are 3 text object in drawing that have an extra property should be match with
DwgName as content.
in other word, I have three text in one drawing and when I try to open this drawing, these 3 text should show DwgName in contents. two of these text without ".dwg" and third with ".dwg" suffix.
so I should add a lisp function in autocad's "ACAD2013DOC.LSP" file to run for every drawing that I open it.
does anybody has a solution?
1 REPLY 1
Alfred.NESWADBA
in reply to: aqdam1978
first: in the documentation you'll read that you should not modify the ACAD2013DOC.LSP, you should use the ACADDOC.LSP instead.
Therefor you don't need a programm or tool, just use the FIELD-functionality (>>>details<<<).
[EDIT] see the waring about the ACAD<version>DOC.LSP >>>here<<< [/EDIT]
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
