Visual LISP, AutoLISP and General Customization
TDINDWG v TDUSRTIMER
4 REPLIES 4
Moshe-A
593 Views, 4 Replies
Hi Guys,
and have another question...
does these two sysvar returns the same elapse time?
if so? one is redundant or again i am missing something?
thanks
Moshe
4 REPLIES 4
Moshe-A
in reply to: Moshe-A
OK Guys,
i have figured it out, the TDUSRTIMER can be reset by the user via TIME command (whereas TDINDWG not)
dbroad
The only way I know to reset the TDINDWG is to save the drawing as a template, close and reopen the template and save the file back as a drawing.
Architect, Registered NC, VA, SC, & GA.
Moshe-A
in reply to: dbroad
thanks dboard,
i didn't look to reset tdindwg i just wanted to know what's the diffrent between them
scot-65
in reply to: dbroad
Good to know.
What I discovered is to DXF the DWG, open the DXF in a text editor, find the line,
and set all numbers to 0. Problem is if you do not replicate the exact number of
characters, the DXF can never be converted back into a DWG file.
Scot-65
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
”Boost
