I am trying to render a 3D object and I want the lines to be visible in the final output. However, AutoCAD does not have a setting to do this, so I am considering converting my lines into solids. This will be time-consuming as it will require me to sweep multiple lines, polylines, and splines. If you could please provide me with an alternative solution that saves me time, I would be very grateful. Thank you.
Solved by marko_ribar. Go to Solution.
(defun c:shp-sweep-c ( / *adoc* shp ss i curve lay col shpn el ch )
(or (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil))) (vl-load-com))
(alert "Firstly specify-select curve entities with possibly \"Previous\" input and then pick unit shape curve which is to be swept...")
(vla-startundomark (setq *adoc* (vla-get-activedocument (vlax-get-acad-object))))
(prompt "\nSelect curve entities to make sweeps with unit shape...")
(setq ss (ssget '((0 . "*POLYLINE,LINE,SPLINE,ARC,CIRCLE,ELLIPSE,HELIX"))))
(prompt "\nPick unit shape curve for sweep along selected curves : ")
(while (not (ssget "_+.:E:S:L" (list '(-4 . "<or") '(-4 . "<and") '(0 . "*POLYLINE") '(-4 . "<or") '(70 . 1) '(70 . 3) '(70 . 5) '(70 . 9) '(70 . 13) '(70 . 129) '(70 . 131) '(70 . 133) '(-4 . "or>") '(-4 . "and>") '(-4 . "<and") '(0 . "SPLINE") '(-4 . "<or") '(70 . 3107) '(70 . 2051) '(70 . 1067) '(70 . 11) '(-4 . "or>") '(-4 . "and>") '(-4 . "<and") '(0 . "ELLIPSE") '(-4 . "<and") '(41 . 0.0) '(42 . 6.28319) '(-4 . "and>") '(-4 . "and>") '(0 . "CIRCLE,REGION") '(-4 . "or>"))))
(prompt "\nEmpty sel.set... Please pick unit shape for sweep along curves again...")
(setq shp (ssname (ssget "_P") 0))
(setq sss (ssadd) el (entlast))
(if ss
(repeat (setq i (sslength ss))
(setq curve (ssname ss (setq i (1- i))))
(setq lay (cdr (assoc 8 (entget curve))))
(setq col (vla-get-color (vlax-ename->vla-object curve)))
(setq shpn (vlax-vla-object->ename (vla-copy (vlax-ename->vla-object shp))))
(vl-cmdf "_.SWEEP" shpn "" curve)
(while (< 0 (getvar 'cmdactive)) (vl-cmdf ""))
(entupd (cdr (assoc -1 (entmod (subst (cons 8 lay) (assoc 8 (entget (entlast))) (entget (entlast)))))))
(vla-put-color (vlax-ename->vla-object (entlast)) col)
(prompt "\nEmpty sel.set... Please select curve entity(ies) next time when routine is started again...")
(if (= "Yes" (if (null (progn (initget "Yes No") (setq ch (getkword "\nDo you want to remove path curves [Yes/No] <Yes> : ")))) "Yes" ch))
(progn
(vl-cmdf "_.ERASE" ss "")
(while (setq el (entnext el))
(ssadd el sss)
(prompt "\nNewly created 3DSOLIDS are selected in selection set in variable \"sss\"... You can call it with (c:sss)")
(sssetfirst nil sss)
(progn
(prompt "\nSelection set with path curves is highlighted...")
(sssetfirst nil ss)
(vla-endundomark *adoc*)
(princ)
Is it possible to provide set base point of the profile ?
thanks in advance
