Im looking for ideas on how I could check a text file if it has been modified.
im not looking to find out what specifically has been done, just that if file changed in some way.
i thought about checking the date, when last saved to the current date but not really sure how to go about
comparing them.
any thought, ideas or suggestions is appreciated.
You might want read about vl-file-systime. You could do two successive reads and compare them and allways save the last one somewhere, like in the registry or some other external file:
vl-file-systime
Returns last modification time of the specified file
(vl-file-systime filename)
Arguments: filename
A string containing the name of the file to be checked.
Return values:
A list containing the modification date and time, or nil, if the file is not found. The list returned contains the following elements:
Note that Monday is day 1 of day-of-week, Tuesday is day 2, etc.
Examples:
_$ (vl-file-systime "c:/program files/AutoCAD 2002/sample/visuallisp/yinyang.lsp")
(1998 4 3 8 10 6 52)
@andrew.nao wrote:Im looking for ideas on how I could check a text file if it has been modified.
comparing them.
I don't believe you can do that. If the display options in Windows Explorer are any indication, there's only one "Date Modified" category of information available, which as far as I can tell knows only the last time it was saved. I don't think a file contains any information about previous times it may have been changed. There's a "Date Created" choice, but I don't imagine that would do you any good, either -- even the first time a new file is ever saved will be more recent than that [unless it's just a copy of another file; see below]. And even if you could compare multiple modification dates, it wouldn't necessarily mean the file was changed -- someone could have opened it, looked around, changed nothing, and then unnecessarily saved it, instead of just getting out of it without saving. That would change its "Date Modified," but its contents would be the same. Likewise in a file that's currently open, you could compare its Date Modified to the current date/time, but there's little point in that, because the comparison will always come out the same, and it won't necessarily mean anything has been changed since the last time the file was saved.
If I copy a file and paste it somewhere, its Date Created is when I pasted it, but its Date Modified is still the last-modified date of the file it's a copy of, which means the copy's Date Modified is earlier than its Date Created. In that situation, I think you can be certain that the copy has not been changed, because any saving of changes would of course move the Date Modified to later than the Date Created. But I can't think of a way to be sure that a file in isolation has been changed since any given earlier time.
However, if you have two files, presumably [in the context of your question] versions of the same file in different folders or something, I think there are ways available to compare their contents, within limits.
@ Somebuddy
thanks Ill check out the sysvar variable
@Kent
I only have 1 file and yea your right about the saving and not necessarily edited the file.
there has to be some clever way to do this.
@andrew.nao wrote:how about if i compare to filesize instead of the file date?
That's another check that may or may not give you a definitive answer. If the file sizes are different, you could assume something about the content is, too. [Even then, there may be no substantive difference -- it could just be a lot of added blank lines or something.] But if someone changed a "white" to a "black," or a 10 to a 99, or any number of other kinds of changes, the file size wouldn't be any different. As with SomeBuddy's suggestion, you would need to have saved a reference of some kind outside the file itself, to compare to, whether that's a copy of the file or a little piece of information about its size at the reference date/time. But you're probably going to need something like that, no matter what approach you end up with.
@Anonymous wrote:....
year month day-of-week day-of-month ....
That's curious, in a way. I wonder what the day-of-week entry is in there for -- I wouldn't think that would matter to most people compared to the month and date, but it must be information that someone wants at least sometimes. But it complicates the process of comparing files' last-modified dates, if that's what someone wants to do with the information.
Today would return
(2010 9 5 17 ....)
and next Tuesday would return
(2010 9 2 21 ....)
If you wanted to know which of two dates/times returned by that function is earlier or later, you could compare the first [year] numbers, and if they're different, you have your answer. If they're the same, you move over one, and compare the next [month] numbers. But if those are also the same, you can't get an answer by comparing the third [day-of-week] numbers, because in the case above, doing that would suggest that next Tuesday is before today. But then beyond that, again you can just compare the numbers for the date and after, until those in some position come out different.
So to make a comparison function, you would need to step through something like (nth) functions with positional arguments built to move up from 0 to 1 to 3 and beyond, bypassing position 2.
[As an aside, I find that the function also returns one more number at the end than the AutoLISP Reference describes. It's a three-digit integer, which I assume must be thousandths of a second.]
I wasn't talking about a system variable, but about a VLISP function and I don't think that there is a more clever way to do this other than using a function built for this purpose.
Regards
