Visual LISP, AutoLISP and General Customization
Stuck in a routine 2
9 REPLIES 9
Message 1 of 10
msarqui
693 Views, 9 Replies
Hi guys,
I made this routine and it works very well for me but I have a issue that I can not figure out how to do.
Basicaly, the routine asks for the user to choose the hatch type (Retirer/Percer), then the layer (Defpoints/Select/Current) and finaly the type of the object to draw (Polyline/Rectangle). My original routine has also a Circle and a Boundary options, and an Error trap to reset the variables but I will keep it simple for the purpose of my issue.
So, my issue is: when I choose the type of object to draw, it draws just one of it and the routine ends. I would like to have something that "says" to the routine that I want to keep drawing that object (Polyline or Rectangle) and putting the hacth inside until I do enter and then the routine goes to its end.
Can I have any help please?
Thanks!
9 REPLIES 9
Message 2 of 10
msarqui
in reply to: msarqui
Did I put the file attached?
The new look of the site is a mess...Smiley Very Happy
;;;;;;;;;;;;;;;;;;;;;;;;;;;;; SUBFUNCTIONS ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
;;get the layer needed
(defun selectobject ()
(command "select" nil);to remove selection if an object is already selected
(command "laymcur")
(princ "\nSelect an object to take its layer:")
(setvar "cecolor" "BYLAYER")
(setvar "celtype" "BYLAYER")
(command pause);wait until I draw the rectangle or the pline
(setq Layerselectobject (getvar "clayer"))
;draw rectangle
(defun drawrectangle ()
(command "rectang")
(while (> (getvar 'cmdactive) 0) (command pause));while the command is active, wait...
;draw pline
(defun drawpline()
(command "pline")
(defun createLayerDef ()
;create layer if not present
(if (tblsearch "layer" "Defpoints")
(command "_.-layer" "_U" "Defpoints" "_T" "Defpoints" "_ON" "Defpoints" "")
(command "_.-layer" "_M" "Defpoints" "_C" "158" "" "")
);if
(setvar "clayer" "Defpoints")
(setvar "cecolor" "30")
);defun
;initget Defpoints Select Current
(defun initgetLayer()
(initget "Defpoints Select Current")
(setq ansLayer (cond ( (getkword "\nSpecify Layer [Defpoints/Select/Current] <Current>: ") ) ( "Current" )))
(cond
((eq anslayer "Defpoints")
(setvar "thumbsize" 1)
);eq
((eq anslayer "Select")
(setvar "thumbsize" 2)
(selectobject)
);eq
((eq ansLayer "Current")
(setq llocalGen (getvar "clayer"));need because Defpoints can be choosen after this
);eq
);cond
;;;;;;;;;;;;;;;;;;;;;;;;;; SET HATCH VARIABLES ;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun sethatchVarRet ()
;set hatch variables
(setvar "hpassoc" 1)
(setvar "hpcolor" "31")
(setvar "hpdraworder" 3)
(setvar "hpname" "ANSI31")
(setvar "hpislanddetection" 0)
(setvar "hplayer" ".")
(setvar "hpang" 0)
(setvar "hpscale" 15)
(setvar "hpseparate" 1)
);defun
(defun sethatchVarPer ()
;set hatch variables Percer en Chantier
(setvar "hpcolor" "2")
(setvar "hpang" 0)
(setvar "hpscale" 1)
(setvar "celtype" "Continuous")
);defun
;;;;;;;;;;;;;;;;;;;;;;;;;;;;; MAIN ROUTINE ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun c:HTT (/ ansLayer ansHatch llocalGen typ)
(setvar "thumbsize" 0);variable randomly chosen to provide the Defpoints option
(setq llocalGen (getvar "clayer"));because I want the hatch in the current layer when I choose Defpoints option
(initget "Retirer Percer")
(setq ansHatch (cond ( (getkword "\nSpecify hatch type: [Retirer/Percer] <Percer>: ") ) ( "Percer" )))
(cond ;for ansHatch
((eq ansHatch "Retirer")
(initgetLayer)
(initget "Polyline Rectangle")
(setq typ (cond ( (getkword "\nChoose [Polyline/Rectangle] <Rectangle>: ") ) ( "Rectangle" )))
(cond ;for typ
((eq typ "Polyline")
(if (= (getvar "thumbsize") 1) (createLayerDef))
(command "multiple")
(drawpline)
(setvar "clayer" llocalGen);need to remade the current layer over Defpoints to make the hatch
(if (= (getvar "thumbsize") 2) (setvar "clayer" Layerselectobject));because I want the hatch in the choosen layer
(sethatchVarRet)
(command "_.bhatch" "s" "l" "" "")
);eq Polyline
((eq typ "Rectangle")
(drawrectangle)
(sethatchVarRet)
);eq Rectangle
);cond typ
(princ "\nHatch *Retirer* finished.")
);eq
((eq ansHatch "Percer")
(initgetLayer)
(cond ;for typ
(drawpline)
(sethatchVarPer)
);eq Polyline
(drawrectangle)
(sethatchVarPer)
);eq Rectangle
);cond typ
(princ "\nHatch *Parcer* finished.")
);eq
);cond ansHatch
(princ)
);defun
Message 3 of 10
marko_ribar
Here is quick fix...
  (command "select" nil)                ;to remove selection if an object is already selected
  (command "laymcur")
  (command pause)                       ;wait until I draw the rectangle or the pline
                                        ;draw rectangle
  (command "rectang")
                                        ;draw pline
(defun drawpline ()
  (command "pline")
  )                                     ;if
)                                       ;defun
(defun initgetLayer ()
  (setq ansLayer
         (cond
           ((getkword
           ("Current")
  (cond
    )                                   ;eq
     (selectobject)
    )                                   ;eq
     (setq llocalGen (getvar "clayer")) ;need because Defpoints can be choosen after this
    )                                   ;eq
  )                                     ;cond
  (setvar "hpang" 0)
)                                       ;defun
  (setvar "hpang" 0)
)                                       ;defun
(defun c:HTT (/ *error* ansLayer ansHatch llocalGen typ ch)
  (defun *error* (msg)
    (if msg
      (prompt msg)
    (princ)
  (setvar "thumbsize" 0)                ;variable randomly chosen to provide the Defpoints option
  (setq llocalGen (getvar "clayer"))    ;because I want the hatch in the current layer when I choose Defpoints option
  (setq
    ansHatch (cond
               ((getkword
               ("Percer")
  (cond                                 ;for ansHatch
     (initgetLayer)
     (setq typ
            (cond
              ((getkword "\nChoose [Polyline/Rectangle] <Rectangle>: "))
              ("Rectangle")
     (cond                              ;for typ
        (while
          (progn
              (createLayerDef)
            (drawpline)
            (setvar "clayer" llocalGen) ;need to remade the current layer over Defpoints to make the hatch
            )                           ;because I want the hatch in the choosen layer
            (sethatchVarRet)
            (initget "Yes No")
            (setq
              ch (getkword "\nContinue with drawing [Yes/No] <Yes>: ")
            (if (or (eq ch "Yes") (eq ch nil))
              t
              nil
          )                             ;progn
        )                               ;while
       )                                ;eq Polyline
        (while
          (progn
              (createLayerDef)
            (drawrectangle)
            (sethatchVarRet)
            (initget "Yes No")
            (setq
              t
              nil
          )                             ;progn
        )                               ;while
       )                                ;eq Rectangle
     )                                  ;cond typ
    )                                   ;eq
     (initgetLayer)
     (setq typ
            (cond
              ("Rectangle")
     (cond                              ;for typ
        (while
          (progn
              (createLayerDef)
            (drawpline)
            (sethatchVarPer)
            (initget "Yes No")
            (setq
              t
              nil
          )                             ;progn
        )                               ;while
       )                                ;eq Polyline
        (while
          (progn
              (createLayerDef)
            (drawrectangle)
            (sethatchVarPer)
            (initget "Yes No")
            (setq
              t
              nil
          )                             ;progn
        )                               ;while
       )                                ;eq Rectangle
     )                                  ;cond typ
    )                                   ;eq
  )                                     ;cond ansHatch
  (princ)
)                                       ;defun
 HTH, M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 4 of 10
msarqui
in reply to: marko_ribar
Hi Marko.
It is a very good solution, thanks. Because of your answer I started to learn about the "WHILE" statement.
I do not understand one thing:
If ENTER = nil (http://www.afralisp.net/autolisp/tutorials/program-looping.php), why this other routine does not stops when I hit ENTER?
(defun C:Rept ( )
  (while
   (setvar "hpcolor" "8")
   (setvar "hpdraworder" 1)
   (setvar "hpname" "solid")
   (command "rectang")
 );while
(princ)
);defun
Like the command COPY, I would like to have something that will repeat until I hit ENTER. 🙂
Message 5 of 10
alexKoshman
It's because the "(while (setvar ... ...)" is ALWAYS TRUE!
Message 6 of 10
alexKoshman
in reply to: alexKoshman
Try this: (defun C:Rept ( / pt1 Flag) (setq Flag T) (while Flag (setvar "hpassoc" 1) (setvar "hpcolor" "8") (setvar "hpdraworder" 1) (setvar "hpname" "solid") (setq pt1 (getpoint)) (setq Flag pt1) (command "rectang" pt1) (while (> (getvar 'cmdactive) 0) (command pause)) (command "_.bhatch" "s" "l" "" "") ) ; while (princ) ) ; defun Sorry for formatting... it doesn't work here... : (
Message 7 of 10
msarqui
Hi Alex
(setq Flag T)                                             ;so, you are setting FLAG = TRUE
(while Flag                                               ;and while WHILE = TRUE
        (setvar "hpassoc" 1)                         ;set this
        (setvar "hpcolor" "8")                      ;set this
        (setvar "hpdraworder" 1)                 ;set this
        (setvar "hpname" "solid")                ;set this
        (setq pt1 (getpoint))                         ;get a point and set to PT1 for the fisrt point of the rectangle
        (setq Flag pt1)                                  ;set the point to FLAG so if the point is NIL because I hit ENTER, the routine stops?
);while
(princ) );defun
Am I getting this?
Message 8 of 10
alexKoshman
You're absolutely right! ; )
Message 9 of 10
Kent1Cooper
@alexKoshman wrote:
Try this: (defun C:Rept ( / pt1 Flag) (setq Flag T) (while Flag (setvar "hpassoc" 1) (setvar "hpcolor" "8") (setvar "hpdraworder" 1) (setvar "hpname" "solid") (setq pt1 (getpoint)) (setq Flag pt1) (command "rectang" pt1) (while (> (getvar 'cmdactive) 0) (command pause)) (command "_.bhatch" "s" "l" "" "") ) ; while (princ) ) ; ....
I would think, since nothing within the (while) loop is re-setting those hatch-related System Variables back to previous values, you may as well set them just once, and then go into the (while) loop, so that it doesn't set them again for every rectangle & hatch.  Also, after hitting Enter when asked for a point, it will set Flag to nil, but the (while) loop won't be stopped until it gets around to the beginning again to check on the value of Flag.  That means it will still try to draw a rectangle and return an error for the nil point.  And I think you could do it without the Flag variable, something like this [untested]:
(defun C:Rept (/ pt1)
  (while (setq pt1 (getpoint "\nPrompt similar to RECTANG's initial prompt: ")); returns nil on Enter to end (while)
  ); while
  (princ)
); defun
Kent Cooper, AIA
Message 10 of 10
alexKoshman
in reply to: Kent1Cooper
Yes, Kent! That's much more logical shorter and a bit shorter! ; )
”Boost
