Visual LISP, AutoLISP and General Customization
Stringlengt of text?
17 REPLIES 17
Message 1 of 18
171 Views, 17 Replies
How can i determine (calculate) how much space a string is gonna take up as
text in a drawing?
So i mean before it is text.
Paul
17 REPLIES 17
Message 2 of 18
If you mean the length in drawing units ...
(caadr (textbox (list (cons 40 txth)(cons 1 txtv)(cons 41 txtw)(cons 7
txts))))
where txth=height, txtv=value, txtw=width factor, txts=style
Mark
"Paul" wrote in message
news:68EB715F22A2428FB35DBFBE9B11F8D5@in.WebX.maYIadrTaRb...
as
> text in a drawing?
> Regards,
> Paul
Message 3 of 18
Paul,
If you use a monospaced font that you know the spacing, you can be fairly
accurate using the technique Mark suggested. However, in a proportional
spaced font, letters vary in width with each character. "W" is wider than
"H" which is wider than "I".
They do tend to average out. It all depends on how accurate you need to
e. -David
as
> text in a drawing?
> Regards,
> Paul
Message 4 of 18
In your sugestion i already have text. That isn't wat i meant. I nead to
calculate the space it's gonna take up before it is text
Mark schreef in berichtnieuws
4605482049A8B18474C77B2A65BB9B1A@in.WebX.maYIadrTaRb...
> txts))))
> Mark
> as
> > text in a drawing?
> > Regards,
> > Paul
Message 5 of 18
I know that they all have different width, therfore i need a way to
calculate the total width.
David Bethel schreef in berichtnieuws
94A2E30B7B9949F78350E38448AB732E@in.WebX.maYIadrTaRb...
> Paul,
> e. -David
> as
> > text in a drawing?
> > Regards,
> > Paul
Message 6 of 18
Sounds like you need to measure each and every letter, U/Lcase, and if you're
lucky, differences from font to font will be proportional. Then a routine could
be written that predicts overall length of a string of certain font, height,
rotation, etc. Could be fun.
-doug
news:985A4A54C1956AED308A805829048D29@in.WebX.maYIadrTaRb...
> > Paul,
> > e. -David
> > as
> > > text in a drawing?
> > > Regards,
> > > Paul
Message 7 of 18
Something like that. But my idea of fun is different (other hobbies or
drink some beer)
any other ideas???
Doug Barr schreef in berichtnieuws
3B86ADDD723C4DB812122F4D1A8DBC24@in.WebX.maYIadrTaRb...
you're
could
height,
> -doug
> > > Paul,
fairly
proportional
than
to
> > > e. -David
take up
> > > as
> > > > text in a drawing?
> > > > Regards,
> > > > Paul
Message 8 of 18
The way I've worked around it is to place the text, use textbox to measure
it, then erase the text. Clumsy, but it works. I'll be monitoring this
thread with interest to see if someone has another way.
Jim
Message 9 of 18
I don't see why Mark's suggestion doesn't work for you. You seem to be
under the impression that the text must exist for it to work, not so. I
mean you know the text height, text style, width factor, text value and
width factor, right? Most of those things are stored in the text style.
-Jason
news:F66D164ECD23A99B1FA8CDEE184B5E47@in.WebX.maYIadrTaRb...
> drink some beer)
> any other ideas???
> you're
routine
> could
> height,
> > -doug
> > > > Paul,
> fairly
> proportional
wider
> than
need
> to
> > > > e. -David
> take up
> > > > as
> > > > > text in a drawing?
> > > > > Regards,
> > > > > Paul
Message 10 of 18
Paul,
For .shx fonts, the only way would be to have access to the .shp file, step
thru each characters definition, and calculate it's width based on the
original definition. No fun at all. Allow for oblique angles & text size
and you would be close. -David
Message 11 of 18
You don't have to place the text to use the textbox function.
(textbox '((1 . "Jason")))
returns
((0.0 -6.93889e-018 0.0) (0.387931 0.09375 0.0))
-Jason
"Jim Nelson" wrote in message
news:9DDE613E10E39B67F8E897C81A43E3AF@in.WebX.maYIadrTaRb...
> Jim
Message 12 of 18
> returns
Cool! That works great, and would seem to answer the original question of
this thread. I wish someone would have told me that when I posted a similar
question years ago. Thanks!
Message 13 of 18
Your welcome. There is also this Express Tools function (acet-geom-textbox)
that takes two arguments.
(acet-geom-textbox )
The difference is the return value includes the rotation of the text and I
believe the returned coordinates are relative to the entity.
BTW: It is in the help file for the TextBox function.
-Jason
news:7CD43F7535C34447E6D4E37F3B6E2526@in.WebX.maYIadrTaRb...
> > returns
similar
Message 14 of 18
My question is answerd
Paul schreef in berichtnieuws
as
> text in a drawing?
> Regards,
> Paul
Message 15 of 18
I should mention that the is related to the textsize.
0 = no offset
1 = text height
2 = textheight x2
etc....
-Jason
"Jason Piercey" wrote in message
news:896088290673A0FDE54F18ACED6DFA98@in.WebX.maYIadrTaRb...
(acet-geom-textbox)
> -Jason
> > > returns
of
> similar
Message 16 of 18
What I usually do in a case like this is to temporarily create the object
(in this case text) to be analyzed, and then (in this case) use the (in this
case) textbox function to get the required information; then, simply erase
or (entdel) the temporary object. Yes, it's a bit of a kludge, but much
simpler than creating a character width table for every font you're likely
to be using.
___
Message 17 of 18
All these years ... and still learning. Thanks, Jason.
___
news:58C7DB63FE5B6FB3BD1F237A0C69EAC3@in.WebX.maYIadrTaRb...
Message 18 of 18
Glad I could learn ya a little sumthin' 🙂
-Jason
"Paul Turvill" wrote in message
news:33087637815EB8D0E08C9A64B87BC475@in.WebX.maYIadrTaRb...
> ___
”Boost
