The reason you can't stretch things with a pre-defined selection set is that
the Stretch command needs to know how much of the things selected are inside
the crossing window, so it knows whether to move them completely, or change
one end, or whatever is appropriate depending on the entity type.
But in this particular case, I don't think you need Lisp at all. Just grab
the three lines by a crossing (right-to-left) window, with no Command
active, and pick on the grip at the shared endpoint, and drag it wherever
you want. It will stretch all three, the same as with a more explicit
Stretch command.
Kent Cooper
wrote...
Hi hensley,
Thanks!
I could not get "You need to select 2 points for the corners of a crossing
that include the ends of your 3 lines"
Can you please tell me by creating Lisp code for the same line.
I hope I am not bothering you.
Thanks for your help.
Sumit
