It will load a little faster if all are in one file, but probably not enough
to notice on a fast computer.
Only you can determine if is it worth your time.
One advantage is having fewer files to keep track of.
If you are using a custom menu, you can put them in a .mnl file for the menu
but don't put them in the acad.mnl file.
Loading a routine multiple times will not cause a problem, unless you are
resetting global variables during the load that you might want to keep.
Jim Claypool
jclaypool@kc.rr.com
"john crocco" wrote in message
news:2002A4EDE22D6DC44E85FC78E52CF72A@in.WebX.maYIadrTaRb...
> I have converted from R14 to 2002. I am useing R14 lisp routines and
bonus
> tools in 2002 as well. However, when Autocad 2002 loads, it loads now 7
> .LSP files AND the .MNL. Is there any advantage to combining the 7 lisp
> files into just one, or two? Would that make it load faster? Is there
any
> problems running or loading the same things multiple times if its
duplicated
> in multiple lisps?
> I Kinda figure there IS an advantage, I guess what I am asking is it
Really
> worth my TIME to do that?
> John Crocco
> Cartland Company
> jcrocco@cartlandco.com
