Visual LISP, AutoLISP and General Customization
ssname resulting in nil
15 REPLIES 15
Message 1 of 16
399 Views, 15 Replies
I have a selectionset wich consists of 22 entity's.
But when I do (ssname ss1 1) it results in nil
How can this be? Shouldn't this always result in an entitylist?
Can anyone enlighten me?
M
15 REPLIES 15
Message 2 of 16
I ment to say:
(entget (ssname ss1 1)) results in nil
(ssname ss1 0)
(ssname ss1 1)
(ssname ss1 2)
And so on.
Result in an entityname.
"M. Janmaat" schreef in bericht
news:6095921@discussion.autodesk.com...
M
Message 3 of 16
H.vanZeeland
what are the result of
(vlax-erased-p (vlax-ename->vla-object (ssname ss1 1)))
if the result is T then the object is erased.
or maybe a audit will help
Cheers
Harrie
Message 4 of 16
1))
results in nil
Here the results of 0 and 2;
_1_$ (vlax-ename->vla-object (ssname ss1
0))
#<VLA-OBJECT IAcadBlockReference 0afe74e4>
_1_$
(vlax-ename->vla-object (ssname ss1 2))
#<VLA-OBJECT
IAcadBlockReference 0afe7474>
_1_$
what
are the result of
(ssname ss1 1)))
erased.
help
Cheers
Harrie
Message 5 of 16
H.vanZeeland
Very strange,
The result of (vlax-ename->vla-object (ssname ss1 1)) gives also a vla-object?
And the result of (vlax-dump-object (vlax-ename->vla-object (ssname ss1 1)))
Harrie
Message 6 of 16
Harrie,
(ssname ss1 1) results in <Entity name:
7e9e2ab0>
Both result in nil.
I don't get it either. Wich explains my
post.
I've created a workaround for it.
Thanks for the replies.
M.vr.gr. (assuming your Dutch)
M
Very
strange,
And the result of
1)))
Harrie
Message 7 of 16
Can you post a drawing with the entity that fails
with (entget) ?
That should only happen if the entity is erased.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
"M. Janmaat" wrote in message news:6095931@discussion.autodesk.com...
Harrie,
Both result in nil.
I don't get it either. Wich explains my post.
M
schreef in bericht news:6095928@discussion.autodesk.com...
Very strange,
Harrie
Message 8 of 16
helo
dont try it that way, if I may, try this.. I dont know further explanation but this works..
1. replace entsel with ssget in your routine..
2. if you want to use entsel,
(setq blah (vlax-ename->vla-object (car (entsel))))
but i prefer the first one.. much simpler
Message 9 of 16
I threw the drawing away.
Here a new one. this one also goes wrong. Now with the first entity in ss1.
I do get the ename. Not the elist.
But I've "solved" my problem. Well... solved. I don't need a solution
anymore. I've created a woraround.
I prefer to follow the path of least resistance. You know, like the
"collapse" of WTC1, 2 and 7 on 9/11 : ) : )
M
"Tony Tanzillo" schreef in bericht
news:6095998@discussion.autodesk.com...
with (entget) ?
Harrie,
Both result in nil.
M
Very strange,
vla-object?
1)))
Harrie
Message 10 of 16
Need to use ssget.
Thanks.
helo
this works.. 1. replace entsel with ssget in your routine.. 2. if you want to
use entsel, (setq blah (vlax-ename->vla-object (car (entsel)))) but i
Message 11 of 16
Just a guess...
What may be happening is the selection set is being modified, example calling ssdel,
within a loop function like repeat or while.
That could cause the error you reported.
Joe Burke
M
Message 12 of 16
You're right!
This was the problem;
Somwhere along the way I exploded a block wich caused this to happen.
When I explode a block I would also have to remove it's entityname from the
selectionset.
Thanks!
"Joe Burke" schreef in bericht
news:6096463@discussion.autodesk.com...
Just a guess...
calling ssdel,
Joe Burke
M
Message 13 of 16
You're welcome.
Message 14 of 16
You'll have to do better to help isolate the problem(if you still want a
solution). Provide actual code, not vague snippets. Identify which objects
to select.
Post code complete enough to test and with instructions how to test. Its
more likely a coding problem on your part than an error in either lisp or a
drawing.
On my tests, nothing went wrong.
Example: (setq ss (ssget))
(entget (ssname ss 0)) returns good entity data. Same goes for any number up
to sslength-1.
news:6096442@discussion.autodesk.com...
M
with (entget) ?
Harrie,
Both result in nil.
M
Very strange,
vla-object?
1)))
Harrie
Message 15 of 16
It was a coding problem on my part.
Sorry for the inconvenience.
In some other linked code I exploded a block after the selectioset.
"Doug Broad" schreef in bericht
news:6096523@discussion.autodesk.com...
to select.
drawing.
to sslength-1.
M
with (entget) ?
Harrie,
Both result in nil.
M
Very strange,
vla-object?
1)))
Harrie
Message 16 of 16
Glad you found it.
news:6096533@discussion.autodesk.com...
to select.
drawing.
to sslength-1.
M
with (entget) ?
Harrie,
Both result in nil.
M
Very strange,
vla-object?
1)))
Harrie
”Boost
