ssget with custom prompt
9 REPLIES 9
Message 1 of 10
4590 Views, 9 Replies
Lately I was talking to friend of mine, an AutoCAD programmer with lisp and
VBA, and he complained in some extend about ssget lisp function that did not
have an argument for programmers custom prompt input. I did one for me later
and I shared it with my friend. I'm sharing the same code with you guys too.
You may find it useful. I implement/mimic the ssget behavior as match as I
needed for my program; single and/or multiple add and remove options are
provided. The attached zip file contains the source and a compiled fas file
that you can incorporate to your fas/lisp/vlx libraries. The test/sample
file has detail information how to use it.
9 REPLIES 9
Message 2 of 10
pnorman
This is just a question. Not a criticism!
I don't see the advantage over just doing:
(princ "Select objects to be changed...\n")
(setq SS1 (ssget))
And your function wouldn't let me right click to finish selecting?
Regards
Phill
Message 3 of 10
Tom Smith
I agree with Phil. Seems like as admirable effort, but not something I've had occasion to care about. I just do an initial (prompt) then accept the standard selection prompt,
Message 4 of 10
Luis Esquivel
It can be done using something like:
[code]
(prompt "Your prompt goes here: ")
(setvar "nomutt" 1)
(setq ss (ssget)) ;; your selection set setup goes here
(setvar "nomutt" 0)
[/code]
Make sure to have "nomutt" part of an error handler
Message 5 of 10
Tom Smith
And be sure the eror handler is totally bulletprooof! People go crazy when their Command prompt disappears 🙂
Message 6 of 10
Tom
Nice post!
Regards Gary
My Mutts name is B.J.
Message 7 of 10
Tom,
Also considering the dog policy at Adesk H.Q I think this is a bit cruel!
Regards Gary
www.drcauto.com
Message 8 of 10
I didn't know this????
(setq SS1 (ssget))
cooooooollllllllllll
"quiz" wrote in message
news:5268332@discussion.autodesk.com...
provided. The at
Message 9 of 10
; Marc'Antonio Alessi, Italy
; http://xoomer.virgilio.it/alessi
; Function: ALE_SsGetFilter
; Version 1.00 - 22/02/2005
; Version 1.01 - 04/03/2006 - added (setvar "ERRNO" 0)
; Description:
; Ssget with filter list
; Arguments:
; PrmStr = User prompt [STR]
; FltLst = ssget filter list
    ; Example:
    ; (ALE_SsGetFilter "Select attibuted block(s)" '((0 . "INSERT") (66 . 1)))
    ; Return Values:
    ; [PICKSET] Selection set
    ; nil if user press 'Return' or 'Space'
    (defun ALE_SsGetFilter (PrmStr FltLst / FlgSlt SelSet)
    (setvar "ERRNO" 0)
    (princ "\n_ ")
    (prompt (setq PrmStr (strcat "\n" PrmStr ": ")))
    (if
    (while (not FlgSlt)
    (if (setq SelSet (ssget FltLst))
    (not (setq FlgSlt T))
    (if (= 52 (getvar "ERRNO"))
    (setq FlgSlt T)
    (prompt (strcat "\nNo objects selected or valid, try again!"
    PrmStr))
    (not (princ "\nFunction cancelled. "))
    SelSet
Message 10 of 10
ranjith0326
in reply to: Luis Esquivel
good solution
R.Ranjith
”Boost
