I am working to snag a selection set of a specific dynamic block... for some reason some of them are anonymous blocks... this is as I would have expected.
For others, they are not anonymous blocks... and simply this code works
(setq ss (ssget "X" (list (cons 0 "INSERT")(cons 2 "ROOM TAG"))))
So... for the anonymous blocks I have to check the effective name:
(defun GetRoomTags (/ inc blockname en finalss ss)
(setq ss (ssget "X" (list (cons 0 "INSERT")(cons 2 "`*U*"))))
(setq inc 0)
(setq finalss (ssadd))
(while (setq en (ssname ss inc))
(setq blockname (vla-get-effectivename (vlax-ename->vla-object en)))
(if (wcmatch (strcase blockname) "ROOM TAG")
(ssadd en finalss)
(setq inc (1+ inc))
finalss
Why would there be 'Room Tag' (s) inserted both as anonymous as well as named blocks. I know that they have a 'effective name' property... but not certain why the same dynamic block would be inserted in the drawing file in two ways.
If looks as though I may have to get the anonymous blocks as well as the named blocks and push them into the same selection set.
Solved by mdhutchinson. Go to Solution.
@mdhutchinson wrote:I am working to snag a selection set of a specific dynamic block... for some reason some of them are anonymous blocks... this is as I would have expected.
(setq inc 0)
(ssadd en finalss)
(setq inc (1+ inc))
finalss
Dynamic block behaves that way when altered from the orignal state.
That's the reason...
... they turn to anonymous blocks... "when they are altered from the original state"
Thanks!
