Matteo,
Check out this section in the help files:
AutoLISP Developer's Guide > Using the AutoLISP Language > Using AutoLISP to
Manipulate AutoCAD Objects > Selection Set Handling > Selection Set Filter
Lists >
Logical Grouping of Filter Tests
hth,
David Kozina
wrote in message news:6145153@discussion.autodesk.com...
Hi all, got an ssget problem, hope that some one can help me out.
I'm using
(ssget '((0 . "DIMENSION")))
to select some objects.
but what I whould really like is to select only rotated and aligned dims, so
I changed it to
(ssget '((0 . "DIMENSION") (70 . 0) (70 . 1)))
but it doesn't work.
any help?
Matteo
