Visual LISP, AutoLISP and General Customization
Splines to their correct elevation
6 REPLIES 6
samu3
1451 Views, 6 Replies
Hi all,
I have a (2D) drawing with hundreds of elevation lines as splines. They all have their supposed z elevation as text next to them. Is there a lisp that would raise these splines to the elevation in the text by firstselecting the spline and then clicking on the elevation text?
Thanks!
Samu
6 REPLIES 6
pbejse
in reply to: samu3
@Anonymous wrote:
Hi all,
Thanks!
Samu
(defun c:elevate (/ spl txt elev)
  (vl-load-com)
  (prompt "\nSelect Polyline")
  (while (and (setq spl (ssget "_:S:L" '((0 . "*POLYLINE"))))
	      (not (redraw (setq pl (ssname spl 0)) 3))
	      (princ "\nSelect text for elevation:")
	      (setq txt (ssget "_:S" '((0 . "TEXT"))))
	      (numberp
		(setq elev (read (vla-get-textstring (vlax-ename->vla-object (ssname txt 0)))))
	      ) ;_ end of numberp
	 ) ;_ end of and
    (redraw pl 4)
    (vla-put-elevation (vlax-ename->vla-object pl) elev)
    (princ (strcat "\nElevation at " (rtos elev 2 2)))
  ) ;_ end of while
  (princ)
HTH
hmsilva
in reply to: samu3
samu3 wrote:
...I have a (2D) drawing with hundreds of elevation lines as splines....would raise these splines to the elevation in the text
by firstselecting the spline and then clicking on the elevation text?...
it if they are splines, and not lwpolylines with the spline option ...
they are 3d objects and don't have the elevation property, each fit point may have different elevation,
So, if they all have the same elevation, try this code:
(defun c:test(/ tx)
 (prompt "\nSelect contour line to change elevation : ")
 (command "select" "single" pause)
 (setq tx (cdr (assoc 1 (entget (car (entsel"\nSelect elevation text : "))))))
 (command "change" "p" "" "p" "e" tx "")
 (PRINC)
Hope that helps,
Henrique
pbejse
in reply to: hmsilva
Henrique
Good point Henrique
(if (vlax-property-available-p (vlax-ename->vla-object pl) 'Elevation) (progn (vla-put-elevation (vlax-ename->vla-object pl) elev) (princ (strcat "\n<<<Elevation at " (rtos elev 2 2) ">>>")) )(princ (strcat "\n<<<Unable to Change Elevation>>>")))
Holler if you need help putting this together samu3
HTH
stevor
in reply to: samu3
A procedure: 1. SSget all TEXTs that could be associated with the SPLINE entities that you want to 'reaise.' 2. For each TEXT entity, use a ssget "w" or "c" of appropriate size to get the closest SPLINE. 3. and modify that SPLINE entity/object, or create another and delete that one, at the new coordinates. If you post a sample DWG, make it just a few of the objects, and in an old dwg format, like 2000, and no reactors; to get the most help.
S
samu3
in reply to: samu3
Sorry for the late reply... But thank you so much guys, you solved my problem! Appreciate it!
Samu
pbejse
in reply to: samu3
Samu
Happy to help samu3
Cheers
”Boost
