Spline to pline
8 REPLIES 8
Message 1 of 9
375 Views, 8 Replies
Spline to pline
is there a routine which one can use to convert a spline to a polyline?
thanks
Colin
8 REPLIES 8
Message 2 of 9
Colin, What do you hope to accomplish? Would you want the translated version to be a spline curve fit pline or one that uses straight or arc curved segments to most closely approximate the spline curve? Regards, Doug "colin1234" wrote in message news:7967882.1096020604543.JavaMail.jive@jiveforum2.autodesk.com... > is there a routine which one can use to convert a spline to a polyline? > > thanks > > Colin
Message 3 of 9
BillZ
If you just want a facsimile of your spline:
Use the measure command at desired distance and use the points to draw you pline. This can be done programically.
Untested:
(defun dup_spline (/ ent d1)
(setq ent (car (entsel "\nselect spline")))
(setq d1 (getdist "\nDistance between points."))
(command ".measure" ent d1)
(setq ptlist (ssget "P"))
(setq cnt 0)
(command ".pline")
(repeat (sslength ptlist)
(setq pt (cdr (assoc 10 (entget (ssname ptlist cnt))))
cnt (1+ cnt))
(command pt)
(command "cl")
;(entdel ent) ;remove semi colin to del spline
Bill
Message 4 of 9
BillZ
Oh yeah,
If you want the points removed add (command ".erase" ptlist "")
(setq cnt 0)
(command ".pline")
cnt (1+ cnt))
(command pt)
(command "cl")
Bill
Message 5 of 9
I want the polyline to match the spline line such that after conversion i can change the width of the polyline easily to suit the purposes of the drawing.
Message 6 of 9
The FLATTEN command in 2004 and 2005 will convert it. "colin1234" wrote in message news:7967882.1096020604543.JavaMail.jive@jiveforum2.autodesk.com... > is there a routine which one can use to convert a spline to a polyline? > > thanks > > Colin
Message 7 of 9
BillZ
Thanks Jim.
I didn't know that.
Bill
Message 8 of 9
http://www.dotsoft.com/freestuff.htm download spl2pl.vlx spl2pl converts a selection set of splines to polylines inside the drawing. "colin1234" wrote in message news:7967882.1096020604543.JavaMail.jive@jiveforum2.autodesk.com... > is there a routine which one can use to convert a spline to a polyline? > > thanks > > Colin
Message 9 of 9
Hi Colin [code] (command "_.DXFOUT" "Temp.dxf" "_OBJ" MySplinesSelectionSet "" "_VER" "_R12" "_BIN" "_.DXFIN" "Temp.dxf" ) [/code] Cheers -- Juerg Menzi MENZI ENGINEERING GmbH, Switzerland http://www.menziengineering.ch
”Boost
