Sorting a list of lists
2 REPLIES 2
347 Views, 2 Replies
I got a situation when developing some routines with lists. I tried to solve it, but I couldn’t do it for several days. For example, there are some lists like below;
(((a b) (1 2 3)) ((c d) (1 2 3)) ((e f) (4 5 6)) ((g h) (1 2 3)) ((i j) (7 8 9 10)) ((k l) (1 2 3 4 5)) ...)
I want to get results with each frequency of second lists like below;
result1 : (((1 2 3) 3) ((4 5 6) 1) ((1 2 3 4 5) 1)...)
result2 : (((a b) (1 2 3)) ((c d) (1 2 3)) ((g h) (1 2 3)))
Sorting the lists are the most biggest challenge of my new geometric sover.
Thanks in advance.
2 REPLIES 2
_gile
Hi
For result1, you can use the following generic CountBy function
;; gc:CountBy
;; Counts the items of a list by the key generated by the specified function.
;; Returns a list of dotted pairs in which the first item is the key and the second the number of occurences.
;; Arguments
;; fun : the key generator function
;; lst : the list to process
(defun gc:CountBy (fun lst / key pair res)
  (setq fun (eval fun))
  (foreach l lst
    (setq key (fun l)
	  res
	      (if (setq pair (assoc key res))
		(subst (cons key (1+ (cdr pair))) pair res)
		(cons (cons key 1) res)
(gc:CountBy 'cadr '(((a b) (1 2 3)) ((c d) (1 2 3)) ((e f) (4 5 6)) ((g h) (1 2 3)) ((i j) (7 8 9 10)) ((k l) (1 2 3 4 5))))
returns: (((1 2 3 4 5) . 1) ((7 8 9 10) . 1) ((4 5 6) . 1) ((1 2 3) . 3))
For result2, you can have a look at the vl-remove-if(-not) function.
(vl-remove-if-not
  '(lambda (x) (equal (cadr x) '(1 2 3)))
returns: (((A B) (1 2 3)) ((C D) (1 2 3)) ((G H) (1 2 3)))
Or, use the following generic GroupBy function and deal with the returned list
;; Groups the items of a list by the key generated by the specified function.
;; Returns a list of lists in which the first item is the key.
;; Arguments
(defun gc:GroupBy (fun lst / key sub res)
  (mapcar
    '(lambda (l) (cons (car l) (reverse (cdr l))))
    (foreach l lst
      (setq res
	     (if (setq sub (assoc (setq key (fun l)) res))
	       (subst (vl-list* key l (cdr sub)) sub res)
	       (cons (list key l) res)
 (setq groupedList (gc:GroupBy 'cadr '(((a b) (1 2 3)) ((c d) (1 2 3)) ((e f) (4 5 6)) ((g h) (1 2 3)) ((i j) (7 8 9 10)) ((k l) (1 2 3 4 5)))))
returns:
  ((1 2 3 4 5) ((K L) (1 2 3 4 5)))
  ((7 8 9 10) ((I J) (7 8 9 10)))
  ((4 5 6) ((E F) (4 5 6)))
  ((1 2 3) ((A B) (1 2 3)) ((C D) (1 2 3)) ((G H) (1 2 3)))
You can also get result1 from the list returned by gc:GroupBy:
(setq result1 (mapcar '(lambda (x) (cons (car x) (length (cdr x)))) groupedList))
Gilles Chanteau
GileCAD
GitHub
in reply to: _gile
Fantastic! Man! 🙂 It looks pretty simple, but what I was doing? Thanks for the biggest help.
”Boost
