I searched a lot this problem here, but I couldn't get an proper answer.
Please see the attached drawing. There are some cases to sort selection sets.
How can I handle it as per the cases?
Thanks in advance.
Solved by pbejse. Go to Solution.
Solved by Hallex. Go to Solution.
@Anonymous wrote:....
Try out BlockSSSort.sp [= Block Selection Set Sort] early on this thread:
If you have messages listed chronologically, it's attached to message 9. It's for Blocks specifically, sorting positionally by insertion point, but could easily be adjusted for other entity types.
Your Case 1 would be done thus:
(BSSS "L" "B")
Case 2:
(BSSS "L" "T")
Case 3:
(BSSS "T" "L")
It takes a selection set, and returns a sorted list of entity names.
If I've been understand this right
this code snip does your work
(setq ss nil data nil tmp nil ee nil) (setq ss (ssget '((0 . "text")))) (while (setq en (ssname ss 0)) (setq lst (entget en) pt (cdr (assoc 10 lst)) txt (cdr (assoc 1 lst))) (setq tmp (cons pt txt)) (setq data (cons tmp data)) (ssdel en ss) ) (setq case1 (vl-sort data '(lambda (a b) (and (or (> (caar a)(caar b)) (< (cadar a)(cadar b))) (<= (caar a)(caar b)))))) (setq case2 (vl-sort data '(lambda (a b) (and (or (< (caar a)(caar b)) (> (cadar a)(cadar b))) (<= (caar a)(caar b)))))) (setq case3 (vl-sort data '(lambda (a b) (and (or (<= (caar a)(caar b)) (>= (cadar a)(cadar b))) (> (cadar a)(cadar b))))))
Hallex, you must be a genius. I greatly works for me. It doesn't look difficult but I couldn't make it. Thanks man. 🙂
Hallex,
And also see below routine.
(defun c:test ()
(setq ss nil
data nil
tmp nil
ee nil
(setq ss (ssget '((0 . "INSERT") (66 . 1))))
(setq tmp (cons pt en))
(ssdel en ss)
) ; end of while
'(lambda (a b)
(and (or (<= (caar a) (caar b))
(>= (cadar a) (cadar b))
(> (cadar a) (cadar b))
(setq o 0)
(while (setq a1 (nth 0 case3))
(setq a2 (car a1))
(setq i (polar a2 (dtr 35.2336) 514.8099))
(command "text" i "68.0" "0" (rtos (+ 1 o) 2 0))
(setq o (1+ o))
(setq case3 (cdr case3))
) ; end of while
) ; end of defun
(defun dtr (a) (* (/ a 180.0) pi))
(defun rtd (a) (/ (* a 180.0) pi))
BTW, an error occurred at the marked one. Please give it a try and advice me what happened.
Besides, when I use not a window selection but slecting object one by one, this doesn't work properly.
Thanks in advance.
(defun c:NumB (/ aDoc op ptlst mn mx) (vl-load-com) (setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object)) i 0 ) (cond ((and (progn (initget "W S") (setq op (getkword "\nSelection Method [Window/Select Order] <Window>: ")) (if (not op) (setq op "Window")) T) (ssget '((0 . "INSERT") (66 . 1))) (progn (vlax-for itm (setq ss (vla-get-ActiveSelectionSet aDoc)) (vla-getboundingbox itm 'mn 'mx) (setq ptlst (cons (mapcar (function (lambda (a b) (/ (+ a b) 2.))) (vlax-safearray->list mn) (vlax-safearray->list mx) ) ptlst ) ) ) (vla-delete ss) T );progn (foreach box (if (eq op "W") (vl-sort ptlst (function (lambda (ip1 ip2) (< (car ip1) (car ip2)))) ) (reverse ptlst)) (vlax-invoke (vlax-get (vla-get-ActiveLayout aDoc) 'Block) 'AddText (itoa (setq i (1+ i))) box 50;<--- Text Height ) ) ) ) )(princ) )
The window option would process the selecton Left to Right otherwise use the "Select Order" < S >
HTH
if you're going to use the code above in conjuntion with kents code
use something like this
(defun c:NumBs (/ aDoc ss op mn mx blsort2) (vl-load-com) (setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object)) i 0 blsort2 nil;<---temp. for testing puropose ) (cond ((and (progn (initget 1 "LB TL LT") (setq op (getkword "\nSelection Method [LB/TL/LT]: ")) ) (setq ss (cond ((eq op "LB") (BSSS "L" "B")) ((eq op "TL") (BSSS "T" "L")) ((eq op "LT") (BSSS "L" "T")) ) ) (foreach itm ss (vla-getboundingbox (vlax-ename->vla-object itm) 'mn 'mx) (vlax-invoke (vlax-get (vla-get-ActiveLayout aDoc) 'Block) 'AddText (itoa (setq i (1+ i))) (mapcar (function (lambda (a b) (/ (+ a b) 2.))) (vlax-safearray->list mn) (vlax-safearray->list mx) ) 50 ;<--- Text Height ) ) ) ) ) (princ) )
I'm sure kent will use an entirely different though 🙂
Try instead, btw this is another one sorting case
(defun c:test () (setq ss nil data nil tmp nil ee nil ) (setq ss (ssget '((0 . "INSERT") (66 . 1)))) (while (setq en (ssname ss 0)) (setq lst (entget en) pt (cdr (assoc 10 lst)) ) (setq tmp (cons pt en)) (setq data (cons tmp data)) (ssdel en ss) ) ; end of while ;;; (setq case3 (vl-sort data ;;; '(lambda (a b) ;;; (and (or (<= (caar a) (caar b)) ;;; (>= (cadar a) (cadar b)) ;;; ) ;;; (> (cadar a) (cadar b)) ;;; ) ;;; ) ;;; ) ;;; ) (setq case0 (vl-sort data '(lambda (a b) (< (caar a) (caar b))))) (setq c 1) (while (setq a1 (car case0)) (setq a2 (car a1)) (setq pt (polar a2 (dtr 35.2336) 514.8099)) (command "_text" pt "68.0" "0.0" (itoa c)) (setq c (1+ c)) (setq case0 (cdr case0)) ) ; end of while ) ; end of defun (defun dtr (a) (* (/ a 180.0) pi)) (defun rtd (a) (/ (* a 180.0) pi))
